noisy front suspension
Old 26 Feb 2012, 01:23 pm
Angry noisy front suspension
I have had a clunking noise when I go over a bump, so I replaced my struts because my 02 cruiser has 145,000 miles, so I thought it was time, but didn't stop my clunking noise in both left and right side What can be the cause besides the struts.
Old 26 Feb 2012, 01:42 pm
UptownSport's Avatar
Default Re: noisy front suspension
There's lots of stuff in a front end that wears over time-
PT it's the Lower Control Arm rear bushings (LCA's)
Sway bar end links
Ball joints if they haven't been regularly greased
Inner (and more so) outer tie rod ends
Hub caps
Loose brake pads
Old 26 Feb 2012, 02:56 pm
Sway bar end links
Hub caps
Loose brake pads
That about covers it!
Except for the loose nut behind the wheel. Just kidding. I just couldn't stop myself.
Old 26 Feb 2012, 06:36 pm
cannesman's Avatar
I'm sure you can gain a great deal of knowledge here, look into UptownSports remarks and links provided. Welcome to the forum ( great intro by the way ).
Welcome to the forum and welcome home Brother
It's the wife's PT......but I get to drive it on occasion
2003 Inferno Red GT.........no mods.....stock.
Old 26 Feb 2012, 08:03 pm
Sway bar end links
Hub caps
Loose brake pads
What would be the procedure for checking these parts?>
Old 26 Feb 2012, 08:06 pm
Sway bar end links
Hub caps
Loose brake pads
What would be the procedure for checking the front suspension you suggested be the problem?
Old 26 Feb 2012, 09:17 pm
Jack it up and look-
There's lots of posts, especially on the LCA rear bushings
Old 27 Mar 2012, 09:36 am
Uptown,
Just went through this exact same problem. Had the "front end falling off" sound from the front end. So i replaced my struts, they were in need anyways, but didn't fix the problems. So i did a little research and found that the lower ball joints would cause the hanus noise. Bought OEM lower control arms with the ball joints already installed. Installed those and the noise was no longer there. Not sure if that is whats wrong with yours but i was stumped for a while on that very same issue and this solution fixed mine. G/L.
Old 27 Mar 2012, 11:33 am
Everything is visual,
You should be able to pull on bottom of wheel to check for ball joint looseness. OE Chrysler joints seem to be very good (neon still has originals)
but need to have a shot of grease to purge water now and then.
Chrysler shows a procedure (with vehicle static); crawl under, and 'wiggle'
grease fitting with fingers- there's a value for how much it should move.
It may pay to install the 'urethane' bushings in control arms' rear-
Have them on Neon for last decade- They're not perfect, but will outlast OE bushings.
These guys know more about them, but 'prothane' was name we used on Neon.
I don't believe control arm's front bushing needs attention, just rear.
Obviously, inner and out tie rods are just a looseness check
Old 27 Mar 2012, 07:54 pm
I had the same issue but when I looked under the car I could clearly see that the issue is my lower control arm bushings. Things are probably throwing off my alignment and killing my gas mileage a bit.
2001 pt cruiser limited
2000 audi s4 built 2.8l twin tial 770r
2002 audi tt 225 quattro 35r
Noisy front end. dpj450 Tech & Performance Forum 4 25 Jan 2012 07:52 pm
Front suspension advice classiccruiser Wheels, Tires, Suspension 12 31 May 2011 12:48 pm
front end suspension babygms2005 Wheels, Tires, Suspension 9 10 Dec 2010 08:26 pm
front suspension noise RaceWilson Wheels, Tires, Suspension 7 23 Apr 2010 07:12 am
Front Sway bar / suspension question.. 06PT General PT Cruiser Discussions 7 06 Dec 2007 10:33 pm
