Widest wheel/tire combo stock suspension?
Old 03 Mar 2012, 06:37 am
Default Widest wheel/tire combo stock suspension?
Hi
I am looking for some more contact patch on the stock suspension. Right now the stock 15 in steelies are dedicated snow tire wheels, so I need to pick up or custom order something else for summer ( Ultra/ high performance wanted). I didn't see much tire selection for the stock 15s so I guess a 16in wheel might be better....haven't checked what is out there yet, as I am not sure what will clear. I also want to stay with a steel wheel for cost and looks, maybe diamond racing or another similar company, or maybe just a junkyard if they are available ?
Anyone know?
Old 03 Mar 2012, 11:31 am
Default Re: Widest wheel/tire combo stock suspension?
I'm using 18x8.5 38mm offset with 235 40 18 tires.
Old 03 Mar 2012, 01:05 pm
But those aren't steel. I don't think any thing that nice is available in steel.
Old 03 Mar 2012, 01:10 pm
That's true
Old 04 Mar 2012, 11:55 am
That's a good start thanks. Any clearance issues? How close to the shocks are the inner tire, fender lip? Did you need spacers/studs or anything?
Old 04 Mar 2012, 12:13 pm
The tires are about 1/2 inch to the bottom of the strut. I'm using 5mm spacers and I had to grind a few mm from the caliper bracket...but I think is only need it because of the wheel design ( deep dish ) and the bigger GT brakes. I had no rubbing at all with the Eibach springs...now with the Goldline Super Slammers, I get some rubbing on the inner fender under fast cornering...but I believe is fixable with a little fender rolling.
But look how close I'm to the edge of the fender...
What is the Widest/Tallest tire on Stock 17" 03RedGTPT Wheels, Tires, Suspension 6 22 Aug 2009 03:26 pm
noob here: biggest wheel/tire combo? teahead Wheels, Tires, Suspension 5 26 Apr 2008 11:53 am
Widest Tire on stock rim? PTGT Redman General Turbo Discussions 19 28 Nov 2003 02:31 am
Age old question (again) max tire size stock wheel BobM_CT Wheels, Tires, Suspension 8 21 Nov 2003 02:53 am
Widest tire on stock turbo wheels rnbenoit Turbo Wheels/Suspension/Handling 6 16 Sep 2003 03:12 pm
