Knocking from rear driver side wheel when braking
Old 15 Mar 2012, 09:50 am
Cartmansnuts's Avatar
Default Knocking from rear driver side wheel when braking
I just replaced the rear shoes and drums on my 03 NA. Now when ever I brake there is this annoying knocking coming from the rear of the car. Anyone else had this problem?
Silver '03 NA, K&N Gen 2 Cold Air Intake, Borla Cat back 2.25 dual out, 18" Gunmetal Drag DR-19's , 225/40 ZR18, Tokico Blue shocks and struts with Eibach Pro springs. Soon (money and wife permitting) PTeazer front fascia w/ retro grill, power cowl hood and rear rollpan. In the back of my mind: Kenne Bell Optimizer II (If I can find one).
Old 15 Mar 2012, 09:58 am
Default Re: Knocking from rear driver side wheel when braking
Take it back apart and see what you did wrong.
Old 15 Mar 2012, 10:06 am
Sorry, should have said that I have already. Put it back the same as the passenger side which isnt knocking. Since I really dont enjoy replacing parts if they dont need replacing I would like to get some options as to what it might be.
Old 15 Mar 2012, 11:27 am
Didn't get the front shoe and rear shoe swapped?
Old 15 Mar 2012, 11:32 am
No, I got them in the right place.
Old 15 Mar 2012, 11:35 am
It sounds like a bad hub...I had a similar noise when braking and it was the hub
Old 15 Mar 2012, 12:06 pm
Thanks Gus, how much of a job is that to replace?
Old 15 Mar 2012, 12:47 pm
Is not that expensive... $60 here but probably you can find it cheaper...
Wheel Bearing And Hub Assembly National 512167
Old 15 Mar 2012, 01:41 pm
rcktpwrd's Avatar
If it is a hub, make sure you get the correct one, they are different for disk brakes and drum brakes... RockAuto has them as well for decent prices and Advance Auto always has some sort of discount codes too.
Joel
www.rcktpwrd.com
Old 15 Mar 2012, 04:28 pm
Did it make this noise before the brake work?
Screech from front driver side wheel griz Tech & Performance Forum 1 24 Mar 2011 06:05 pm
Help! Rear driver side door will not latch! nobodysfool55 General PT Cruiser Discussions 7 17 Feb 2011 09:17 am
Rear driver side compartment JD78 Interior Accessories Forum 1 26 Dec 2009 07:56 am
KNOCKING ON FRONT PASSENGER SIDE SUSSPENSION PATGAS Wheels, Tires, Suspension 2 11 Oct 2009 12:48 am
Driver Side Rear rattle or squeek Imdaddog PT Cruiser Convertible Forum 1 28 Nov 2007 01:06 pm
