control arm bolts
Old 19 Mar 2012, 10:45 am
Flowrider's Avatar
Default control arm bolts
Hi is it difficult to remove the rear control arm bolt (the vertical bolt) with just a breaker bar? Also does it need to be torqued at 180 ft lbs? I have a beam style torque wrench but it only goes to 70 ft lbs.
Old 19 Mar 2012, 11:00 am
Default Re: control arm bolts
I never use a torque wrench...I use a ratchet with a 1" x 16" pipe at the end for that bolt
Old 19 Mar 2012, 11:05 am
davea300's Avatar
Mine was rusted solid (bad winters over here). Had to make a cut in the chassis to get to the nut. The other one came out with heat and breaker bar. Not a job I look forward to again! Use lots of penetrating fluid first.
2005 2.4 PT CRUISER (UK SPEC)
Short ram intake, chrome grill, chrome belt line, drilled/slotted discs, few flames, engine dress up, chrome bits and pieces.
67,000 miles
Old 19 Mar 2012, 11:51 am
Flowrider's Avatar
Thanks guys, looks tough to loosen. I'll def give that a try. Need to get some more PB Blaster too.
Old 19 Mar 2012, 02:01 pm
UptownSport's Avatar
That was the hardest bolt I've ever loosened;
After they came loose, there were the problem of the spacer rusted to the bolt.
In short, if you have Winter's Like Dave and Minnesota do, and the car is old, find a discount liquor store.
Old 19 Mar 2012, 02:33 pm
davea300's Avatar
Good advice. I was going to change my front struts at the same time but got put off doing it because of the hassle with the control arms! Still havent done them! Hope they are easier!
67,000 miles
Old 19 Mar 2012, 03:11 pm
rcktpwrd's Avatar
I used a 1/2" breaker bar on mine and they both came right out.
My car started life on L.I. Before we moved to NC, so it's not like it never saw winters...
Joel
www.rcktpwrd.com
Old 19 Mar 2012, 09:31 pm
Flowrider's Avatar
LOL yeah I'll make sure I'm stocked up. Then afterwards when I'm done, I can celebrate
Old 19 Mar 2012, 09:56 pm
A pipe on a breaker bar works better. It easier on the ratchet. The key here is the pipe!
Missing bolts bogaz Tech & Performance Forum 5 23 Nov 2011 12:25 pm
Transmission Bolts Leroy Tech & Performance Forum 7 12 Nov 2010 06:24 pm
Missing bolts! Musicman General Turbo Discussions 2 25 May 2010 05:22 pm
oil pan bolts stainless1 Exterior Accessories Forum 5 31 May 2006 10:51 pm
Lug bolts KurtPT Wheels, Tires, Suspension 0 11 Aug 2003 09:49 pm
