Lowered pt's
Old 19 Mar 2012, 05:28 pm
davea300's Avatar
Default Lowered pt's
Those who have lowered your pt, have you stuck with oem type front struts or went for another kind? I need two new front shocks but wanted to lower the car as well. Struggle to find tokio blues over here!
2005 2.4 PT CRUISER (UK SPEC)
Short ram intake, chrome grill, chrome belt line, drilled/slotted discs, few flames, engine dress up, chrome bits and pieces.
67,000 miles
Old 19 Mar 2012, 05:49 pm
808's Avatar
808 808 is offline
Default Re: Lowered pt's
You can get by with a mild drop on stock struts. Actually, rek ran the Candy Drops on stocks all around I believe. It depends on your tolerance level, but you'll probably look to replace them not too far down the road if yours are going bad. It'll fail a lot sooner.
You might as well just replace the struts at the same time to avoid a dangerous situation.
Old 19 Mar 2012, 06:30 pm
ROCKETMAN8060's Avatar
I got some eBay item numbers for you!
320819707855
400241403177
ROCKETMAN8060
Old 19 Mar 2012, 06:31 pm
xwing777's Avatar
Mine was the complete coilover kit from H&R. I have heard everyone that used the stock struts had to replace them not long after wards as is to much wear and tear on them.
Old 19 Mar 2012, 09:17 pm
I lowered mine with the Eibach Pro kit. I really like the way it looks and levels the car. When I swapped the springs I also changed my struts and shocks. I used Monroe Sensatracs all around. I like the way it rides, I dont think its bad at all. The blue struts were a bit out of my price range at the time I needed to change them.
Old 19 Mar 2012, 09:45 pm
I used the H&R lowering springs and Tokico blues.
Old 20 Mar 2012, 10:27 am
Found this for you
F/S EIBACH LOWERING SPRINGS
ROCKETMAN8060
Old 20 Mar 2012, 11:54 am
davea300's Avatar
Originally Posted by ROCKETMAN8060 View Post
Found this for you
Thanks for finding that and the ebay items. Unfortunately for me i think shipping to the uk will prove to be expensive. My pt is due for its annual mot test next month and i think it will fail on the front struts, maybe not but i reckon they need replaced anyway. I'm going to have a look around the web and see what I can find.
67,000 miles
Old 20 Mar 2012, 02:24 pm
808's Avatar
808 808 is offline
I'm selling Eibach's too
Old 20 Mar 2012, 03:08 pm
jwlast's Avatar
How about just a spring kit to just lower the rear? Just looking to level the car. Does it need a shock change and which springs work best. Any other issues (realign required, etc?)
Thanks, learning tons on this forum!!!!!
JT
LOWERED or NOT Wolfman Wheels, Tires, Suspension 9 14 Apr 2011 11:08 am
Show us your lowered PT's !!! 05silverGT Wheels, Tires, Suspension 19 09 Aug 2008 04:59 pm
Lowered PT's CREWZIN Wheels, Tires, Suspension 16 11 Mar 2008 11:19 pm
lowered 2 in souptownyamaha Wheels, Tires, Suspension 2 20 Jun 2004 11:25 am
Lowered bigdogdad Exterior Accessories Forum 23 23 May 2004 07:27 am
