CV Axle Separates
Old 25 Mar 2012, 06:51 pm
Default CV Axle Separates
I bought this 03 GT as a project car. I've got the engine running, but I am having right CV axle problems. The previous owner put new ones in last January. The right motormount and right lower torque mount were completely shot. As a result, when I got the engine running the car would not move as the shaft had pulled out of the wheel assembly. I greased and reassembled it. I had trouble with engine timing and I ran the engine with no mounts bolted in to be sure it was OK. I put everything back together and drove it about 1o miles and all was OK. Today I backed it out of the garage, turned it sharp to left and it pulled out. So...is the axle bad and needs replacement, or did it come most of the way loose working on the timing and then pulled out when I backed out? If I need a new axle-recommendations on where to buy one? Thanks.
Old 26 Mar 2012, 02:11 pm
UptownSport's Avatar
Default Re: CV Axle Separates
I'm not at all familiar with the GT, if I understand correctly it as equal-length
shafts (there's a solid shaft directly behind the engine that has a bearing attached
where the old '01-'02 had crank sensor) and uses two 'Left" axles
Either he got an axle too short (Neon, turbo Dodge and many other axles are
nearly interchangeable)
has the powertrain adjusted causing a severe shaft angle, or the center mount is also broken.
You're saying the joint itself is coming apart inside the boot, or it's pulling out of the jackshaft?
Tags
cv axle, separation
Rebuilding CV axle (halfshaft) bobdole369 Tech & Performance Forum 0 26 Dec 2011 08:33 pm
CV Axle GoosedF350 Wheels, Tires, Suspension 1 13 Dec 2011 09:59 pm
Picked up a new rear axle rcktpwrd Wheels, Tires, Suspension 8 20 Nov 2011 11:31 pm
Bellcrank - rear axle argos587 Wheels, Tires, Suspension 11 07 Jul 2010 07:27 am
10K, 1 Year, & Needs New Axle??!! jlwn111 General PT Cruiser Discussions 28 27 Jun 2010 07:26 pm
