Disc Brakes Question?
Old 14 Apr 2012, 01:10 pm
Default Disc Brakes Question?
So my 2008 has a little shake when the brakes are applied and i can hear some rubbing noise at times so i will be replacing the brakes and depending on the price the rotors too. What should I stay away from? thanks!
Spooky
2008 Touring Edition 26,000 Miles
R.I.P. Penny
2001 - Limited Edition - 234,067 + Miles
120,000 spark plugs Bosch Platinum 4
135,000 - Timing belt,
170,000 - Radiator
190,000 PCV and hose
200,000 Spark plugs Bosch Platinum IR Fusion
200,235 - Oil Sensor
Old 14 Apr 2012, 01:58 pm
Default Re: Disc Brakes Question?
Anything cheap quoted to you that's too good to be true. Your life depends on a good set of brakes.
Old 14 Apr 2012, 03:28 pm
Call all your local parts houses and check prices. Can vary a bunch. I use after market rotters all the time without any issues. Pads will be determined by how much wheel dust you are willing to tolerate. To be honest any pad will stop your car. In fact the cheap ones will tend to react quicker but will ware much quicker and dust up in excess. A middle grade or higher will be the best rout to go. If your car has rear drums, you might make sure there adjusted up correctly. To insure they are helping out the fronts. If they are not you could warp the new rotters again.
Changing Front Disc Brakes and Front Bumper? HackMATTr General PT Cruiser Discussions 12 14 Feb 2011 12:58 am
How hot should disc brakes get? ptal Wheels, Tires, Suspension 1 01 Dec 2009 09:21 pm
Converting Rear Drum Brakes to disc Matt42 Tech & Performance Forum 1 12 Jul 2009 11:01 pm
03 Pt disc brakes pitman Tech & Performance Forum 3 01 Jun 2008 02:37 pm
UPDATING REAR DRUM BRAKES TO DISC blue Tech & Performance Forum 5 14 Apr 2005 12:01 am
