front strut replacement
  • 1 Post By 808
Old 14 Apr 2012, 03:35 pm
Cartmansnuts's Avatar
Default front strut replacement
So I got my front driver side strut off, i have put together the new blue tokico together with an Eibach spring, but now i cant get the steering knuckle to line up. the strut is about 1" lower then the holes on the knuckle. What now?
Silver '03 NA, K&N Gen 2 Cold Air Intake, Borla Cat back 2.25 dual out, 18" Gunmetal Drag DR-19's , 225/40 ZR18, Tokico Blue shocks and struts with Eibach Pro springs. Soon (money and wife permitting) PTeazer front fascia w/ retro grill, power cowl hood and rear rollpan. In the back of my mind: Kenne Bell Optimizer II (If I can find one).
Old 14 Apr 2012, 05:13 pm
808's Avatar
808 808 is offline
Default Re: front strut replacement
With the 3 top strut mount bolts loose, I had to tilt the rotor out to line up the bottom bolt. Once you get that one in, the upper lines up.
If that doesn't work, you can try what my mechanic did and use a pry bar to pull the knuckle down a bit.
mityqwik likes this.
Old 14 Apr 2012, 05:21 pm
Or unhook the sway bar. But just have to hook it back though. I usuly do it like the above suggestion.
Old 16 Apr 2012, 09:45 am
Thanks guys, turns out its a lot easier if you jack both wheels off the ground! feel like a complete Noob!
Strut Replacement etc.. jjackson23 Wheels, Tires, Suspension 2 22 Nov 2011 07:12 am
Best $21 mod......Front strut bar vadonkey Wheels, Tires, Suspension 105 22 Sep 2011 10:39 am
Passenger side strut replacement, any complications? Kell Tech & Performance Forum 0 02 Feb 2010 02:46 am
Control arm and strut replacement scrisp2 Wheels, Tires, Suspension 0 16 Apr 2009 01:35 pm
New Front Strut Question Gottasmilealot Wheels, Tires, Suspension 3 21 Apr 2008 12:17 pm
