Sway bar links..axel boot
Old 03 May 2012, 05:18 pm
Default Sway bar links..axel boot
Am I ever confused...I am a new "cruiser". I purchased a 2006 touring cruiser from a new car dealership (that sells used cars) and I am running out of time with my 30 day warranty. I had my mechanic put the car up on the lift (after the purchase) and he advided me that the front stabelizer links were improperly installed on both sides. It appears that the links the dealer put on were not the correct links, it had too many washers, it had metal on metal at the connection and the top of the bolt was cut, causing the bolt to cut into the axel boot. Today the dealer agreed to change both links, and the right front axel with genuine Chrysler parts, however the dealer insists that his installation of the metal on metal is correct where my mechanic insists it should be rubber on metal at the connection. Any idea who is correct?
Old 03 May 2012, 06:12 pm
ROCKETMAN8060's Avatar
Default Re: Sway bar links..axel boot
Here is a link when I did mine. You can clearly see how it goes.
ROCKETMAN MOD'S
ROCKETMAN8060
Old 03 May 2012, 07:33 pm
Thanks...exactly what my guy told me...rubber on the metal. I posted as attachments the photos I took while under the car. As you can see, the bolt slit the boot too. Now I just have to figure a nice way to tell the dealer he better not install it incorrectly again.
Again, thanks for your help
Old 03 May 2012, 07:37 pm
That is completely wrong. You can use my pictures so they can install them correctly. After that I won't use them anymore for any other repairs.
ROCKETMAN8060
Old 03 May 2012, 07:50 pm
I can't see that as the problem with the boot. Mayby they did it doing the work. If that qualifies as work!
Old 03 May 2012, 07:52 pm
Is missing the middle part on the linkage that's why is touching the axle.
ROCKETMAN8060
Old 03 May 2012, 08:02 pm
The top of the bolt is really close to the boot..these photos were taken when the car was on a lift. Close up, you can actually see the rough cut edge of the upper bolt. As I saw from rocketmans photos, even before they were put on, there is a bolt-like topper too.
Old 03 May 2012, 08:07 pm
Still doesn't look long enough to touch. But that is the most ridiculous excuse for sway bar link install I'v ever seen!
Old 03 May 2012, 08:08 pm
Your right after I saw the last pict it looks like is not touching. Still the installation is wrong.
ROCKETMAN8060
Old 03 May 2012, 08:28 pm
You are so being kind there ROCKET!
ROCKETMAN8060 likes this.
Axel shaft repair jimdandy243 Western PT Forum 0 13 Apr 2012 01:05 pm
Driver side CV axel.... wheelgarage Tech & Performance Forum 1 17 Jan 2010 09:41 am
Wanted: BTG axel back. PianT Classifieds: Want To Buy 5 05 Apr 2004 11:44 am
End Links front Sway Bar PTGT Redman Turbo Wheels/Suspension/Handling 9 29 Oct 2003 11:59 pm
Rear Sway Mounts/Links onedivinehammer Turbo Wheels/Suspension/Handling 15 25 Oct 2003 09:39 pm
