Question for the infamous candyman
  • 1 Post By chris15
Old 11 May 2012, 07:08 pm
cruisin03pt's Avatar
Default Question for the infamous candyman
Alright so candyman, im lookin to lower the pt. should i buy toxicos and cut some material in my springs, where i can get the drop i want, or buy a set of eibach lowering springs and only get 1-1 1/2 in the front, and 2" in the rear? I would like to put coilovers on it but due to budget issues, it wouldnt be for quite some time.
Old 11 May 2012, 09:53 pm
ROCKETMAN8060's Avatar
Default Re: Question for the infamous candyman
Don't cut the factory springs. Everybody that has done that had major problems with the suspension.
ROCKETMAN8060
Old 11 May 2012, 09:55 pm
WolfmanG's Avatar
ok Eric, i sent Don a PM and a text, so hopefully he'll get back to you asap.
-Danny Wolfman G
Old 11 May 2012, 10:01 pm
WolfmanG's Avatar
here bro, you can check this out too, Lowered pt's you might want to do a search for "Lowered" type threads, but i think 808 has a lot of experience with drops too. you can ask chromenut too.
-Danny Wolfman G
Old 11 May 2012, 11:09 pm
Candyman's Avatar
Smile Re: Question for the infamous candyman
Hey Eric,
I second that you big time don't want to cut your springs. It used to be the thing to do, and on a lot of older rides it was not too big of an issue so long as it was done right, but a PT is set up different and can wind up with major issues that you don't need or want.
I have had countless discussions with people who want to argue this one, but trust me, its just not worth it., and here is the short version of why not.
The rear springs are gravity loaded meaning the vehicle relys much on its own weight to maintain the stick spring in place and therefore if you jack up your PT and relieve pressure off the rear axle assembly, you can pull the rear springs out by hand with no trouble at all. In addition you would notice that the top of the rear springs are smaller at the top in order to help the spring seat properly into the upper cup. Now lets say you were to cut the rear springs, or sag them with a torch. The heat would cause the material in the spring to lose its temper making it brittle and will both tend to sag, and eventually could likely break. If you cut it with a chop saw, the spring may likely not seat proper and can become dislodged. Neither way is much fun. Also if the springs are not cut at exactly the same point you can throw your suspension geometry off causing your tires to wear off center and more than likely pull to one side or the other wit no way to realign.
Front is basically the same but more critical due to more complex issues.
For the amount of drop your talking about, I would look for some Eibechs, or H&R Springs. Both are pretty decent and both have the mild type drop your talking about for somewhere in the neighborhood of a couple hundred bucks. Both are progressively wound for better ride, and its cheap, easy, and the best bang for the buck.
Like you say, Coilovers are nice but pricy, air is even more, and then custom air like I have on mine is in all reality bout the price of another PT and then some.
My best advice, keep an eye out on Craig"s List or Ebay and you can usually find some good deals on decent drop springs. Rear ones just spip in and out by hand, and front go straight replacement on the front strut assembly. Note: If you have never replaced springs on a strut assembly nor have access to a spring compressor, have a shop change them out for you. The springs are under a good amount of tension and can fly off at high velocity potentially ruining your day in a heartbeat.
If you have anymore questions on anything, please let me know.
Check out my Custom PT Club Website: http://westvalleyforum.proboards.com/index.cgi
And my ever growing PT Photo Archives: http://s458.photobucket.com/albums/q...uiserArchives/
Please Like my Hot Rod Restoration and Detail Shop on Facebook.
https://www.facebook.com/BlueDiamondDetailing
Old 12 May 2012, 01:21 pm
Originally Posted by Candyman View Post
Hey Eric,
Ok, thanks for the info guys. Im lookin to get some super slammers, anybody selling any?
Old 17 May 2012, 10:40 pm
chris15's Avatar
Unfortunately, you'll have to wait in line. (Figuratively, not literally haha) They're pretty sought-after springs.. but are definitely worth it once you find them.
WolfmanG likes this.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 06 Jun 2012, 08:07 pm
i found a set online for $211+shipping. lemme go see if i can find them again. says it gives you a 2.0" drop in the front, and a 2.2" drop in the rear. those are the ones im goin with. Gonna use KYB struts too ( i can get them cheaper through work than getting toxico's) I guess we'll have to see how it all turns out.
Question for Mr. Candyman Chromenut The Detail Shop 0 25 Sep 2011 03:37 pm
Detailing Question for Candyman Va_Cruiser The Detail Shop 4 12 Oct 2009 12:15 pm
ANOTHER QUESTION FOR CANDYMAN soonercruiser The Detail Shop 2 12 Aug 2009 10:11 pm
Question for Candyman chintzgirl The Detail Shop 6 13 Jun 2009 01:43 pm
