How do I remove the CV Axle?
  • 1 Post By Chromenut
Old 14 May 2012, 09:47 am
Question How do I remove the CV Axle?
We removed the CV axle from drivers side of 2004 PT and we can't get the inner joint housing pulled out of the transmission. Does anyone have any tricks up their sleeves (or tool boxes) on getting a hold of this smooth housing to give it a good yank?
Old 14 May 2012, 10:34 am
Default Re: How do I remove the CV Axle?
May I ask, are you using a service manual to insure you're following the proper steps for pulling the axle?
Old 14 May 2012, 10:57 am
I just use two small pry bars,(on each side of the axle) between the axle and the tranny. I just do one hard and quick pry and the axle comes right out.
Old 14 May 2012, 10:59 am
Sounds like my love life!
[L][M][A][O]
XtrmDC2 likes this.
Old 14 May 2012, 11:41 am
^ LOL
Old 14 May 2012, 12:04 pm
We followed a couple of website how to's and also a friend (long distance) has been giving instructions. We have everything else disconnected, disassembled and ready to go, just wasn't able to get the housing popped out. I have a large pry bar, but I couldn't get it behind the housing.
Old 14 May 2012, 12:41 pm
UptownSport's Avatar
Yes, even a stout screwdriver. Seems it's better to 'snap' or 'shock' movement, than pressure.
A few of my buddies were able to do it in 8 minutes; we took 20.
Old 14 May 2012, 03:37 pm
I used my ball joint pickle fork between the housing and transmission and give it a quick pull. Pops right out!
2003 GT 5 speed, 2nd owner, 90,000 miles, Stage1, Altezza taillights, TYC backup lights, air box mod
Old 15 May 2012, 07:55 am
Thumbs up Re: How do I remove the CV Axle?
Thanks for all the help and suggestions. I never could get any type of prybar far enough behind the housing to get any kind of leverage, so I went to plan B. A homemade slide hammer did the trick in 1 pull. I used a vise grip to clamp an "L" shaped bracket to the wall of the housing. Then using a piece of threaded rod through a hole in the bracket, with a hunk of steel on the other end. One not so gentle slide and out she came.
How To Remove Front Seats & Remove Or Add Drawer Dill Interior Accessories Forum 20 16 Jul 2014 09:38 am
Axle Bolt janjentay10 Tech & Performance Forum 2 19 Apr 2012 11:41 pm
CV Axle Separates Ikster Wheels, Tires, Suspension 1 26 Mar 2012 02:11 pm
CV Axle GoosedF350 Wheels, Tires, Suspension 1 13 Dec 2011 09:59 pm
10K, 1 Year, & Needs New Axle??!! jlwn111 General PT Cruiser Discussions 28 27 Jun 2010 07:26 pm
