Uneven Brake wear.
  • 1 Post By Chromenut
Old 15 May 2012, 06:26 pm
cocacola144's Avatar
Unhappy Uneven Brake wear.
Hellllooo! I have an '04 PT. Last night my car had a horrendous sound of grinding metal on my way home, it started out with when i was braking.. then it was doing it with everything I finally got home and had it checked out. Not to my surprise my rotors were mutilated. So much shredded metal. from brake to rotor contact. My brakes were down to METAL absolutely nothing left at all..... Heres the kick. I JUUUUUUUSTTT changed them maybe a month ago at the most.. We took the other wheel off and checked the brakes. The brake pads looked NEW ( because they were) So we checked the caliper to see if it was sticking -- nothing... What could be causing this problem? It wore down so incredibly fast, and each front wheels were on other sides of the spectrum - right side completely worn down ruined my rotor... other side in NEW condition.. Help?
I love Petey the PT!
Old 15 May 2012, 06:28 pm
Default Re: Uneven Brake wear.
First of all, you are a lovely lady. That being said, now I can sort of focus on your issue...lol...
When they were changed did they bleed the brakes at all four? If not, you can have an airbubble on one leg and cause the caliper to soften it's push against the pad. That being said, if the brake line has anything in it that could clog it, then all the pressure is going to one side.
cocacola144 likes this.
Old 15 May 2012, 06:35 pm
808's Avatar
808 808 is offline
FASTEST response to a new thread ever!
Hahaha.
Sorry, cocacola, but in all honesty, listen to Chromenut...his entire post.
Old 15 May 2012, 07:36 pm
You have a bad caliper or a hanging one. You wouldn't have air in the line unless you opened a bleed screw or remove a component from a brake line. the only other way would be if you had a leak and ran the break reservoir low on fluid and sucked in air. Hoses have been known to come apart inside and block fluid flow.
Old 15 May 2012, 08:26 pm
^Ditto^ What Busted-PotentialTerrorist said about the brake lines is a possibility!
Old 15 May 2012, 11:08 pm
UptownSport's Avatar
QFT- SUPER common. By the time you jack up wheel to check, it'll have released pressure and seem normal.
Ensure the caliper slides on abutments, they do rust and get divots from rattling pads
Disassemble caliper, inspect bore and piston. Seal kit is only a few $$.
03 turbo gt cruiser has uneven idle when stopped gwynrhyn General PT Cruiser Discussions 12 19 Aug 2011 11:12 am
Uneven touch up PTRobert The Detail Shop 6 28 Sep 2005 08:19 am
uneven acceleration mo-cash General PT Cruiser Discussions 4 22 Jan 2004 11:53 pm
Premature Brake Wear Comments/Solutions Stephen R. Tech & Performance Forum 3 07 Feb 2003 01:00 pm
