front coils rubbing on motormount bolt
Old 17 May 2012, 07:16 pm
Default front coils rubbing on motormount bolt
Hello all, new to the forum and in need of some help. I recently installed a set of Eibach pro springs and Tokico struts. The ride is great but now when turning the steering wheel the front coils rub and pop on what looks like the bolt head that goes through the wheel well to the engine mount on passenger side. Has anyone else come acrossed this problem? Thanks, Dan
Old 17 May 2012, 07:24 pm
Default Re: front coils rubbing on motormount bolt
Have you actually seen them touching?
Old 17 May 2012, 08:23 pm
ROCKETMAN8060's Avatar
Some pictures will help!!
ROCKETMAN8060
Old 17 May 2012, 10:03 pm
UptownSport's Avatar
Good question Busted;
There's lots of space in there- You can't see the mount bolt, it's in the frame
Perhaps the upper strut mount bearings have failed?
Old 18 May 2012, 03:13 pm
Behind the strut assembly are two , maybe large rivets, one above the other.
Not sure what they go to. Will look again tonight and try to take pics.
Old 18 May 2012, 07:53 pm
looked again, looks like the two bolts are to the upper motor mount. I also replaced the control arms with dormans after doing the springs and struts. I think that was when I noticed it more. I just ordered some prothane bushings to put in the original arms. The dorman bushings are way too soft, can see the control arms move when steering is turned. Also going to order new strut mounts while I'm back in there. Anyone know if the KYB mounts are any good or should i go factory or moog? Thanks again
Old 18 May 2012, 11:33 pm
Moog, FTW
That mount- Sorry- was thinking the passenger's 'center' mount
Old 19 Jun 2012, 10:52 pm
UPDATE: I removed the Dorman control arms and put the stock arms with Prothane bushings in and the rubbing went away.
Old 20 Jun 2012, 09:24 am
Must have been for the wrong car. Maybe boxed wrong. Thank's for the update.
Old 20 Jun 2012, 10:15 am
i had someone crank the wheel wheel back and forth while looking around in there. I noticed the control arm would move a little each time from the dorman bushings being so soft. Cant have any give with the tight clearance.
WTB - 06506379AA - Engine mount bolt (frame though bolt) wheelgarage Classifieds: Want To Buy 5 04 Dec 2011 10:31 pm
Tires Rubbing TimWeaver Wheels, Tires, Suspension 10 28 Sep 2010 03:57 pm
Which bolt is the tensioner bolt on the alternator? bjagd02 General PT Cruiser Discussions 6 23 May 2010 10:57 pm
Motormount Questions amazingarthur General Turbo Discussions 13 30 Dec 2004 09:10 pm
Picked up .05 in the 1/8 with motormount K9 Cruiser General Turbo Discussions 18 29 Dec 2004 12:19 pm
