Lifting just a little
Old 23 May 2012, 10:58 pm
Default Lifting just a little
Hi, We just bought a PT and I have seen the posts and pictures of the ones that are lifted. They look cool but, I would really just like it to be only a little higher than stock. Maybe like a couple inches or so. Anyone know what is the best way to accomplish this? I was wondering if I could just go with a larger size tire? Is there room to go with a tire tall enough to make a noticeable difference? If not, is there another way? Thx in advance for the replys, Mark&Deb
Old 23 May 2012, 11:53 pm
cruserdad1976's Avatar
Default Re: Lifting just a little
no sorry btu a larger tire really wont rais the PT in fact im not sure how to but im glad that some one other than me like to LIFT a car
Old 24 May 2012, 12:29 am
One can assume taller wheels and tires equals more ground clearance, but the issue there is that you'll either (1) have issues rubbing inside the fender well on hard bumps, or (2) rubbing against the tranny or inner frame when you turn hard.
There are ways to gain some ground clearance, with taller tires/wheels, but you need to work out the math on how tall you can go without the rubbing issues.
Old 24 May 2012, 12:51 am
Send a message via MSN to Pipeous
there's always those spring spacer things you shove between the coils
2003 Dream Cruiser
The Mean Tangerine: Pteazer Smoothie front fascia, Roadster grill, and Retro real roll pan, dual exhaust, 17" Momo wheels, Eibach lowering kit, 2005 intake, bov, 5 speed manual tranny, painted door pillars, altezza tail lights, hurst short shift kit, hard pipes, halo fog lights and stage 1 computer and injectors
Old 24 May 2012, 09:49 am
shock towers are a issue to
getting the back up is never a issue
getting the frount to go up and stay alinged is the problem
Old 24 May 2012, 11:10 am
ptcru1s3r's Avatar
Since it has just been purchased, it has to be at least 2 years old, so there is bound to be some 'sag' on the standard coils and shocks. So why not just get new coils and shocks and then fit 'spring savers' to the coils?
Ride would be a little bit choppy and I wouldn't take a corner at speed! lol
Old 24 May 2012, 12:13 pm
im not even sure they make AIR shocks for a PT but they would get the back up but its still a issue to get the frount up
Old 24 May 2012, 02:54 pm
chigger_ns's Avatar
you could run airbags. best of both worlds I gusss
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 27 May 2012, 09:43 am
I was thinking the same thing. The stock PT doesn't have much ground clearance. Now my PT sits fairly high. I bought a set of the Monroe Insta-Struts last year when replacing my front shocks, etc. I thought that they would settle more than they have. It's ok, but makes for a somewhat cushy ride. A little too much sway in the front end. I've been somewhat regretting it, and wished I had gone another route. I left the original springs at my brother-in-law's, where we did the work, and I'm sure he tossed them. So, I can't just go back to the originals. But, if you want more height, it's a way to go. It comes as an assembly, spring and all. Want to trade some Insta-Struts for your springs?
2002 Limited Edition, 5 speed
Old 02 Jun 2012, 02:06 am
mdfrodolives's Avatar
I replaced my stock 30,000 mile OEM Goodyears with Big-O Euro's, and when those ran out at prematurely (only 35,000 miles), I got a deal from the Dealer (it really was a good deal, believe it or not) for a set of Kelly Charger GT's, size 205/60R16.
Ever since getting the Kelly's (with that size), I have not scraped my front end while entering parking lots, etc. a single time. Apparently, I get just enough lift from the new tire size eliminate the scraping problem. Also, nothing scrapes while springin' and turnin', and the ride is much quieter!
You might try a set the next time you need tires and save a lot of trouble and expense.
Tim
Lifting a P.T MOPAR_GIRL Exterior Accessories Forum 18 07 Oct 2011 09:08 pm
Lifting rear of PT Cruiser Mooe General PT Cruiser Discussions 2 16 Aug 2010 10:34 am
Lifting a PT? Badger Wheels, Tires, Suspension 2 12 Apr 2008 02:33 am
RE; Lifting kennybopaloo Tech & Performance Forum 17 06 Apr 2004 03:11 pm
