Correct Tire size
  #11 (permalink)
Old 02 Jul 2009, 11:33 pm
Location: Belleuve, WA from Los Angeles - Road Rage specialist
Default Re: Correct Tire size
I did the difference once and it was with a 8inch rim and 235-40-17 and a 235-45-17 tires and the diff was not enough to have an effect on the speedo.. Here is the tool I use to figure this stuff out.. I went with the 235-45-17 just to have that extra bit of sidewall..
Its from the Miata guys, they swap tires more than we change our socks..
Tire size calculator
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
  #12 (permalink)
Old 03 Jul 2009, 10:24 am
I use this website below because it not only measures wheel and tire size but also width and offset of the wheel. But will the 215's rub or should I stick woth the 205's. If the 215's fit, I can get the 18x8's.
Wheel / tire size calculator / comparer - WHEELSMASTER
  #13 (permalink)
Old 03 Jul 2009, 11:12 am
Not a chance in hell 215s will rub when you start getting to the 235s on a 40+offset then you start to worry about things like that.. Go with a 225 you will not be sorry it will just look "right".
  #14 (permalink)
Old 04 Jul 2009, 12:50 pm
AWESOME!!!!
Largest size replacement tire for GT wheel is... Gary04GT Turbo Wheels/Suspension/Handling 12 01 Apr 2006 10:33 pm
Tire size w/ 18's SFsGT03 Turbo Wheels/Suspension/Handling 4 18 May 2004 08:47 am
Does changing the tire size affect ABS? blueberrygt Turbo Wheels/Suspension/Handling 1 16 Apr 2004 09:07 pm
18x8 rims what tire size best dfunkdj Wheels, Tires, Suspension 4 15 Apr 2004 04:04 pm
tire size help cruiser12 Wheels, Tires, Suspension 4 03 Jan 2004 11:29 am
