brake pedal judder
Old 03 Jun 2012, 05:35 am
Default brake pedal judder
i have noticed recently occasionally usually after driving over a bump in the road when i next apply the brakes i can feel a juddering through the brake pedal and i can hear the brakes going on and off almost as if the ABS has kicked in but there is no ABS light on the dash board if i slow the car down to less than 10 mph and apply the brakes they are ok again car is a 2001 touring
Old 03 Jun 2012, 07:02 am
Default Re: brake pedal judder
Dave,
It sounds like you have a warped rotor (maybe two). There are a few shops out there that will check your brakes for free so I suggest you get-er-done.
Old 04 Jun 2012, 03:57 am
i did think of that but would it not judder all the time with a warped rotor mine just seems to do every now and then ?
Old 04 Jun 2012, 04:34 am
Possibly, but that's my guess. Either way, you need to have the brakes checked out or do it yourself by taking the wheels off and giving them a good inspection to see what's wrong.
new here...brake pedal won't depress when cold??? andrew85 Tech & Performance Forum 7 07 Mar 2012 03:37 pm
BRAKE Pedal Arm how to..Automatic mjb457 Interior Accessories Forum 2 06 Mar 2011 11:49 am
brake pedal question Carl48 Tech & Performance Forum 11 22 Mar 2010 07:51 pm
Brake pedal pulsing UncLarryWasRight Wheels, Tires, Suspension 3 06 Jun 2008 06:12 am
replacement gas pedal and brake pedal?? legion Interior Accessories Forum 7 17 Jun 2004 10:06 am
