2002 front wheel bearing
Old 07 Jun 2012, 04:52 pm
Default 2002 front wheel bearing
I need to replace the driver (left) front wheel bearing as it's causing the brakes to screech on corners and may also be a cause for my vibration at 55mph.
Is it the same process as the 2005 as shown on youtube or is it simpler - is it possible to buy the complete knuckle as a unit or do we have to buy the bearings and have them pressed in/out?
Thanks!
Steve
Old 07 Jun 2012, 06:06 pm
Default Re: 2002 front wheel bearing
Press in far as I know. The other way would be way more expensive. Check that your ground straps on the struts are in tack. Wheel bearing will last longer!
Old 07 Jun 2012, 06:39 pm
OK, thanks
I'll check the ground strap. While I was under the car I also found that the nut on the end of the sway bar was missing hence the clunk and also found that the bearing on the rear of the lower control arm was all ripped away so I'm replacing that at the same time!
This corner is getting expensive LOL
Old 07 Jun 2012, 06:51 pm
UptownSport's Avatar
We have to buy the bearings and have them pressed in/out.
Thanks!
Steve
You are correct!
If you can DIY, (relatively) inexpensive.
Saw someone had the LCA rear bushing for $10, bearing is what? $50-60?
Same Deal- I can't paint my car- So if I take it into a body shop $80 worth of paint would turn into hundreds of $$$ (and they'd laugh at me )
Old 07 Jun 2012, 07:56 pm
Originally Posted by UptownSport View Post
You are correct!
It's more like $100s on paint turns to thousands.
Old 07 Jun 2012, 10:41 pm
I did this job on my '02 last summer. They are definitely pressed. The tricky thing is to determine whether the bearings are the larger or smaller size. They changed mid year. Mine were the size of an 01'.
2002 Limited Edition, 5 speed
Old 07 Jun 2012, 10:52 pm
The '01's are 33mm, and the later one's are 39mm btw. When I went to Autozone, they gave me the 39's, and they didn't fit. It's what their computer shows for an '02. Had to take them back.
How to tell which front wheel bearing is bad? sscanlan Tech & Performance Forum 21 13 Dec 2011 11:06 pm
Front Wheel Bearing/Hub Assembly Help UniSaitek Wheels, Tires, Suspension 1 28 Sep 2009 02:34 pm
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
Front Hub & Wheel bearing JoeHundredAire Wheels, Tires, Suspension 2 15 Jun 2008 11:25 am
front wheel bearing debspt Tech & Performance Forum 1 01 Oct 2006 11:42 am
