New brakes
Old 10 Jun 2012, 01:31 pm
Default New brakes
I'm looking for a little advise here. I replaced the front brakes on my '03, and there is a noise coming from the front brakes. There is some slight contact of the pad to the rotor. Everything seems to be installed correctly, and the rotors have also been replaced. I am thinking the pads will wear down, and the noise will disappear. Does this sound right? They are O'Reilly brand brakes, Brakebest, if that makes a difference.
Old 10 Jun 2012, 02:10 pm
UptownSport's Avatar
Default Re: New brakes
Quality is also an issue- pads could be dimensioned different that OE, or whomever made the last set.
Obviously, this shouldn't be.
So the pad may be rubbing on a little spot of rust that wasn't covered by old pad-
I have seen pads- No lie- That weren't installed correctly and dragged on rotor's 'hat' area ...
Walking through junkyards 'learns one up' really quickly on what can be done wrong to a car!
I've also seen calipers that didn't have bolts in, or leading edge of caliper wasn't under abutment, that came loose and (thank God) dragged inside of wheel-
One was on a large straight truck!!!
I think your own judgement on if it's installed correctly is best, if you have doubts, post up a pic- I know Crewzin can spot common mistakes that I'm not familiar with
Old 10 Jun 2012, 02:52 pm
Thanks, Uptown,here are some pics. You can see where the pad has some slight contact with the rotors.
Old 10 Jun 2012, 04:02 pm
Ooops! Sorry! Thought you'd just stuck 'em on an uncut rusty rotor and new friction was hitting rust.
I THINK Crewzin used to point to the little tab thingy's between caliper and abutment, NOT familiar with this brake system in detail- So perhaps he can spot it
Old 12 Jun 2012, 07:38 am
I don't see anything wrong, and with new disks and new pads, the pistons have to be compressed to max, and some contact of pad to disk is expected - by the time you break the pads in (slow from 40 to 20 easily about 10-15 times) the contact should be gone.
e brakes superpug666 Turbo Wheels/Suspension/Handling 2 26 Oct 2009 06:54 pm
brakes... superpug666 Wheels, Tires, Suspension 2 15 Jul 2009 05:08 am
New Brakes... matt87951 Tech & Performance Forum 26 27 Apr 2005 02:38 pm
SRT-4 Brakes bigtommy83 Turbo Wheels/Suspension/Handling 3 03 Dec 2004 02:18 pm
Brakes again! Krys33 General PT Cruiser Discussions 10 14 May 2004 10:33 am
