Loose front wheel hub
Old 18 Jun 2012, 05:50 pm
Default Loose front wheel hub
While in the process of rotating tires, found loose left front wheel. Tire edge
moved about 1/4 inch . Bought new wheel bearing and in getting ready to install found axle nut torqued maybe 30 lbs. Torqued axle nut back to 180
lbs. No play! Reinstalled axle nut hardware and put back on road. So far operating fine.
My PT is 05 GT with 24K miles. I'm not the first owner, so don't know
if bearing has been changed before. Has anyone found factory installed nut
torqued incorrect before?
Thanks for any feed back.
Old 18 Jun 2012, 06:15 pm
Default Re: Loose front wheel hub
No.
Jerry
Old 18 Jun 2012, 08:41 pm
Originally Posted by wwpptc View Post
No.
Jerry
>>>>>>X2.
Old 18 Jun 2012, 09:54 pm
Thanks for the info.
Old 10 Jul 2012, 05:38 pm
Well after driving 100 miles there is no change in front wheel bearing. No new noise and no play in wheel. I think the bearing was not torqued correct or maybe a burr on the housing. ?
Old 10 Jul 2012, 10:33 pm
UptownSport's Avatar
twenty years ago someone I knew took a new, unsold car out and pounded the liven dickens out of it.
It coulda bee left loose at factory or hub coulda bent hitting a curb anytime from off the assembly line to when you got it.
Very good catch, tho!
Groan/creaking sound when turning wheel right (front right wheel) 2k2ptc Wheels, Tires, Suspension 8 02 Sep 2012 10:52 am
Rear Wheel vs Front Wheel OD difference moparmadness Turbo Wheels/Suspension/Handling 0 20 Sep 2011 01:23 pm
Loose Steering Wheel mod71m Tech & Performance Forum 3 10 Jul 2010 07:52 am
loose front end Art Rigby Tech & Performance Forum 2 30 Sep 2009 09:47 pm
Steering Wheel is Loose Stephen R. Tech & Performance Forum 1 12 Sep 2004 12:25 pm
