Longer Bolts/Studs
Old 25 Jun 2012, 09:45 am
ptcru1s3r's Avatar
Default Longer Bolts/Studs
I am looking to install some 20mm hubcentric spacers on the rear of my PT.
The came off a mate with a SEAT Leon and came with longer bolts, but the PT has studs, so does anyone know where I can get longer studs?
Old 25 Jun 2012, 10:56 am
chigger_ns's Avatar
Default Re: Longer Bolts/Studs
Any local auto parts store should carry studs. just measure what you need.
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 25 Jun 2012, 10:16 pm
UptownSport's Avatar
Neon forums had longer from some other OE vehicle- Don't recall which-
But Chigger is right on, you could even do some sleuthing in the Dorman book
Old 26 Jun 2012, 04:39 am
ptcru1s3r's Avatar
Should probably add that I am in the UK and that the local auto parts store is about as much use as a chocolate teapot! What is the Dorman book?
I need a US based onliune retailer that will ship to the UK. Any ideas?
Old 26 Jun 2012, 05:08 am
Just google- dorman auto parts -and take your pick from numerous sites.
Jerry
Old 26 Jun 2012, 07:04 am
SRT-4 Stud Stock Replacement (10 pc. - Axel Set)
Wheel Studs for the dodge srt4 from HorsepowerFreaks
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Wheel studs keep breaking Jaimez Tech & Performance Forum 23 16 Oct 2011 02:50 pm
Sheared Wheel Studs Batman General PT Cruiser Discussions 7 26 Aug 2010 08:35 pm
Replacing wheel studs KingKole02 Tech & Performance Forum 2 04 Feb 2007 04:28 pm
Extened Studs for wheels ESP101 Turbo Wheels/Suspension/Handling 4 19 Nov 2003 08:46 pm
Extened Studs for wheels ESP101 Wheels, Tires, Suspension 1 17 Nov 2003 10:20 pm
