disc brake problem
Old 25 Jun 2012, 12:16 pm
Default disc brake problem
Hi guys. I replaced front pads and rotors on my 04 cruiser. I looked at the rear shoes and they still have a lot of material on them. The drums are also in good shape. My problem is that after bleeding the brakes my brake pedal feels good and firm but when i start the car the pedal feels soft and mushy. So im thinking i screwed up during the bleeding process. The sequence I used is as follows.rr-lr-rf-lf. my question is this right or wrong? Does it make a difference? Im thinking with new pads and rotors my pedal should be a lot firmer! Thanks in advance.
Old 25 Jun 2012, 12:54 pm
Default Re: disc brake problem
Bleeding the brakes not required during a brake job. Do they feel different or worse than before? If this is why you did the brakes to begin with, then you could have a vacuum leak at the brake booster. Where the hose goes on. Or booster or master cylinder might be bad.
Old 25 Jun 2012, 01:04 pm
hi Busted. The brake fluid was brown so i thought I would change it while I was in the garage. The brake pedal is softer with everything new. The brakes had a very nice firm feel before. Is the bleeding sequence right?
Old 25 Jun 2012, 01:08 pm
Lr
Rf
Rr
Lf
Jerry
Old 25 Jun 2012, 01:12 pm
Hi Jerry. question Does it really make a difference changing the sequence?
Old 25 Jun 2012, 05:39 pm
It can depending on the configuring from the manufacture. If Jerry gave that answer then It's pretty much dead on accurate. He is very seldom off on the facts anyway.
Old 25 Jun 2012, 06:06 pm
Jerry and Busted_pt. Hey guys I want to give you both a big thank you very muchfor helping me with my brake problem!! You went out of your way and I really appreciate it!!Thanks again guys !! Boilerhog
Old 25 Jun 2012, 06:11 pm
But did it work? Is the pedal hard again after changing the bleeding sequence?
Rear Disc Brake HELP! PLEASE Sarasmiles Tech & Performance Forum 13 18 Dec 2011 04:46 pm
disc brake grind and buildup yourlefthand Tech & Performance Forum 3 24 Nov 2010 01:17 am
Disc Brake Pads and Rotors . Rich Slider Tech & Performance Forum 18 13 Jan 2006 04:27 pm
Disc Brake Upgrading Stephen R. Tech & Performance Forum 9 31 Aug 2002 12:08 pm
