Do "KLEEN WHEELS" really work???
Old 12 Feb 2004, 01:03 pm
Default Do "KLEEN WHEELS" really work???
WHAT ARE KLEEN WHEELS?
"Kleen Wheels is the well recognized trade name for a patented brake dust shield. A dust shield is nothing more than an INSIDE HUBCAP which fits into the inside of the wheel preventing the unsightly black brake dust from flowing outward onto the outside surface of an alloy or steel wheel. Installation is simple, no special tools needed.
Kleen Wheels are not to be confused with another type of product, since discontinued, a dust cover which completely covered the rotor and caliper. It was kind of a half a rubber football type of affair which really did a good job of keeping in the dust...and also the heat. Kleen Wheels are not to be confused with this earlier type of product! Kleen Wheels are not in any way to be considered a brake product, but merely a wheel accessory because it fits inside the wheel.
ARE DUST SHIELDS STANDARD OE EQUIPMENT ON NEW CARS?
Yes, dust shields are standard factory OE Equipment on certain models. Kleen Wheels has been on the market for over fifteen years - in excess of three million pair on the road.
DO THEY EFFECT THE BRAKES?
Customers often question whether Kleen Wheels have an effect upon the braking system.
Consider a Mercedes-Benz as factory delivered in Germany, usually delivered with a steel wheel and a stainless steel hubcap as standard equipment. Does this wheel/hubcap design allow for any passage of air through the wheel? If an American customer were to buy the same vehicle in the United States, where we usually find the vehicles come standard loaded with alloy wheels, and the customer installs a pair of Kleen Wheels (an inside hubcap) into the alloy wheels - would there be any more or less air circulating through the wheels than the vehicle was originally designed for with a steel wheel and an outside hubcap? The same amount, of course.
HOW DO KLEEN WHEELS FIT?
Kleen Wheels are designed to fit easily into the inside of a wheel, just like an inside hubcap. It is a common misconception that Kleen Wheels fit onto the car. Kleen Wheels are designed to fit the wheel (as opposed to the car). We must always ask "what WHEEL we are fitting", and not "what CAR we are fitting"
To make this point perfectly clear - the Kleen Wheels fit into the wheel like an inside hubcap and therefore the first question we must ask when reading our Application List is WHAT WHEEL ARE WE TRYING TO FIT? Is it a factory original wheel or is it an aftermarket wheel? When ordering, be sure to state whether you are fitting a factory wheel, or which specific after market wheel.
DO KLEEN WHEELS FIT ON THE FRONT WHEELS AND REAR WHEELS?
Kleen Wheels fit both on the front and on the rear of the vehicle. Because the front wheels do 70% of the braking, the front wheels get dirtier far quicker and more easily than do the rear wheels. For this reason customers think that they only need a single pair of Kleen Wheels for the front. Most upscale current model vehicles have disc brakes front and rear.
It is recommended that two pair be installed on a vehicle in order to achieve permanent protection front and rear. Also, when the wheels are rotated, the necessity for removing and replacing the Kleen Wheels is eliminated.
WHAT MATERIAL IS KLEEN WHEELS MADE OUT OF?
Kleen Wheels are manufactured of single-piece construction aircraft grade aluminum, coated with a life-time matte black finish.
HAVE KLEEN WHEELS BEEN OFFICIALLY TESTED?
The world's leading safety standards testing laboratory is in Germany, where the standards are set for safety throughout the world. In Germany this testing is provided by TUV, a government agency created by law to test and evaluate OE equipment as well all aftermarket accessories. Kleen Wheels have been certified and approved by TUV. Keep in mind that we are talking about Germany - where the vehicles are driven on the Autobahn and in the Alps!
IS THERE A GUARANTEE?
Kleen Wheels are guaranteed for the lifetime of the product in the hands of the original purchaser in the original vehicle for which they were purch
Old 12 Feb 2004, 01:15 pm
I guess I'm one of the lucky ones, I have never had a problem with brake dust. Because of that I've never tried the Kleen Wheels, but here are some links to threads from folks who have:
http://www.ptcruiserlinks.com/forum/...s=kleen,wheels
http://ptenthusiasts.org/PTForums/sh...t=kleen+wheels
2002 Inferno Red PT Limited
Mercedes Wiki
Old 12 Feb 2004, 02:22 pm
No more brake dust once I switched to Raybestos ceramic pads. A better solution, IMHO.
Old 12 Feb 2004, 03:27 pm
We installed 2 pairs of Kleen Wheels within a week of getting our PT. They have worked great! We have taken the PT on two long distance road trips, 1900 miles and 2600 miles with no brake fade or overheating problems. I painted them to match the PT and I think it finishes off the openings in the wheels. A lot nicer to look at instead of the rusty rotors and calipers.I would attach a photo but it looks like Imagestation no longer allows linking. Guess I'll have to find another photo hosting site.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 12 Feb 2004, 05:24 pm
Everytime I come across the Klean-Wheels they look like a good idea but I keep thinking they'd restrict air-flow that keep the brakes/rotors nice and cool. I'm guessing of course but it's just the little voices in my head. I've only noticed significant dust build-up after a long road trip with rain the whole way, seemed to make it stick to the rims.
Old 12 Feb 2004, 06:51 pm
BTW- The next time you are down on youe hand and knees in front of the PT, take a look in the openings next to the fog lights and you will see that they direct air right at the rotors for cooling.
John & Terry
Del Val PT Cruisers
Old 16 Feb 2004, 10:47 pm
gonzomania's Avatar
Send a message via AIM to gonzomania
Klean wheels work great. Only problem I encountered which was my fault was that after 100 miles you are supposed to retorque the lugs.
They cut the dust by at least 90%. I only bought them for the front
and rotate them as I rotate the tires because I have front disc rear drum on my basic.
Gonz
Old 17 Feb 2004, 03:24 pm
Have to agree with Don. The Rayestos ceramic pads are the answer. They alone cure 95 % of the dust. I added Powerslot Rotors and get NO DUST. Takes 5 minutes now to clean my wheels instead of an hour.
Greg Gavencky
The New Jersey Cruisers
www.njcruisers.com
Old 17 Feb 2004, 03:37 pm
I had them with the stock wheels, but i need to order a pair for my dream cruiser wheels, but YES they work fine.new brake pads are a good idea too IF you need them, but i don't need pads yet.[8D]
flames&stripes by \"gator\" 2003 milan dragway \"chrysler classic\" winner
Old 19 Feb 2004, 11:45 pm
Send a message via AIM to sakigt
They may work but they look like crap IMO [:I]
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
VW wheels work? 5 X 100 OneBadCruiser Wheels, Tires, Suspension 4 22 Nov 2004 10:18 am
SRT-4 Wheels on the GT blueberrygt Turbo Wheels/Suspension/Handling 3 13 Apr 2004 06:45 pm
Prison or Work? You decide... Gary04GT Non-PT Discussions 1 29 Jun 2003 04:09 pm
Kleen wheels flashbk2 Exterior & Interior Styling 7 27 May 2003 07:14 pm
Kleen Wheels PTKRUZN Exterior Accessories Forum 6 13 Oct 2001 10:07 am
  Wordpress Themes | Expekt bonuses | Creative Electronics | Wordpress Themes | Free Movies
