Front wheel bearing, and I havent seen this question asked before here.
Like Tree2Likes
Old 15 Jul 2012, 07:15 pm
Unhappy Front wheel bearing, and I havent seen this question asked before here.
Ok, Today I was having a friend replace my front wheel bearings. I had gone to Autozone and they gave me a solid bearing, that their system said should fit. My friend got my old bearings off to our surprise, they are a tapered two piece bearing. We can not find this bearing anywhere. I am at a loss and of course being sunday, no one is open to even ask a dealer. So here I am. Where can I find this bearing? I have a 2002, 5 speed Pt. I didn't think I'd run into this issue. Sigh....
Everywhere we called that was open.. ie Pepboys, Checkers, Autozone, OReillys all had the same solid bearing, of which is way too big and isnt tapered to fit. Please help! Ty!
Old 15 Jul 2012, 07:18 pm
compdr59's Avatar
Default Re: Front wheel bearing, and I havent seen this question asked before here.
Look up the P/N from RockAuto. I got mine from Advanced Auto. It was a National Bearing that eliminated play that I had from two Timken's.
Original Owner 135k
Old 15 Jul 2012, 07:29 pm
Ok. One of the guys that were there said he gets parts he can never find from Rock auto. I will let him know! Thank you so much! The bearings that are in are Timkens as well. Do you know if this is the only year that has the tapered bearings? Threw me for a loop trying to figure out why my car is different than others I've asked about today.
Old 15 Jul 2012, 07:33 pm
Also, would the P/n be on the part itself? its Jrm2405 and on the other its jrm2400. I've looked up both and both i get no hits back on.
Old 15 Jul 2012, 07:36 pm
I found it on Advance Auto website! Thank you for leading me in the right direction!
Old 15 Jul 2012, 07:40 pm
Ray_Dockrey's Avatar
Autozone.com shows the bearing you are looking for. Here is the link.
Timken/Wheel Bearing - Front (SET49) | 2002 Chrysler PT Cruiser 4 Cylinders B 2.4L SFI DOHC | AutoZone.com
That link will show my store. You can change it to see if any of your stores has it in stock
Old 15 Jul 2012, 08:13 pm
I thought that was the same one too. We opened the box and its a solid bearing. They have that picture up, but it isnt the same one. We went back to the store and they were dumbfounded too. They couldnt figure out why it was pulling up the wrong bearing. We also went to pepboys and it was the same issue. They have the wrong bearing for my model car. Its crazy i know.. Thank you though! Much appreciated!
Old 15 Jul 2012, 08:27 pm
Every PT front bearing look like this:
https://encrypted-tbn1.google.com/im...Ux8R-107o5_STS
Why don't you take a picture of yours, so we can see why yours is different.
Old 15 Jul 2012, 09:29 pm
UptownSport's Avatar
Xtrm, and Autozone or whomever are correct.
You must be talking of some thing else. These bearings do come apart when removed
Picture?
XtrmDC2 likes this.
Old 15 Jul 2012, 10:17 pm
compdr59's Avatar
Here are actual P/N's from RockAuto. The picture XtrmDC2 showed is accurate. The size of yours should be listed here.
NATIONAL Part # 510058 Ball Bearing; Bore=1.6535", Outer Diameter=2.9921", Width=1.5354"
Front Wheel; 2nd Design; 39mm Width $25.79
TIMKEN Part # 510058 Wheel Race; Ball Bearing Bore=1.6535" Outer Diameter=2.9921" Width=1.5354" Inner Race Radius=0.1772"; "1,5354" in. Width
Opt. Ball Brg.; Front $25.79
SKF Part # FW115 {Click Info Link for Alternate/OEM Part Numbers} Wheel Race; Cone length=1.5354"; Width=1.535"; Outside diameter=2.9920"; Inside diameter=1.6535"; Cup length=1.5354IN
Sealed; From 8/10/01; Front $29.79
NATIONAL Part # 510057 Ball Bearing; Bore=1.6535", Outer Diameter=2.9921", Width=1.2992"
Front Wheel; 1st Design; 33mm Width $40.79
SKF Part # FW129 {#4668442AA} Wheel Race; Inside diameter=1.6535"; Width=1.299"; Outside diameter=2.9921IN
Sealed; Thru 8/10/01; Front $50.79
Original Owner 135k
How to tell which front wheel bearing is bad? sscanlan Tech & Performance Forum 21 13 Dec 2011 11:06 pm
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
front wheel bearing maintenance 4SPEED Tech & Performance Forum 1 29 Oct 2008 05:03 pm
Front Hub & Wheel bearing JoeHundredAire Wheels, Tires, Suspension 2 15 Jun 2008 11:25 am
front wheel bearing debspt Tech & Performance Forum 1 01 Oct 2006 11:42 am
