changed the front wheel bearing today
Like Tree4Likes
  • 4 Post By rob342
Old 20 Jul 2012, 04:56 pm
Default changed the front wheel bearing today
twice!! i put in the bearing. drove about a mile and was like WTF!? is that me? listen a little closer, it IS me! maybe i used the wrong torque stick and the lugnuts came loose? back on the rack to see.. lugnuts are tight. axle nut is tight. wheel wobbles a lot and easily. hmph. take it back apart, the bearing moved. apparently the 2001 has a 33mm and 2002+ have a 39mm wide bearing. anyways. i'm an expert now. all is happy in PT land. LOL!
Old 07 Aug 2012, 06:43 am
Default Re: changed the front wheel bearing today
Originally Posted by Burgess View Post
Hi everyone
this part is very common and after 1 to 2 month will change it.This part control the car.Wheel bearings rotate in the hub and allow the wheel to turn when the vehicle is in motion.
Old 07 Aug 2012, 05:56 pm
UptownSport's Avatar
YEP!
All the 1st gen Neon guys change axles to PT or old Turbo Dodge so outer stub doesn't break:
I THINK you can change that tin bearing retainer piece of tine and swap hubs, but never seen or hear it done
How to tell which front wheel bearing is bad? sscanlan Tech & Performance Forum 21 13 Dec 2011 11:06 pm
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
front wheel bearing maintenance 4SPEED Tech & Performance Forum 1 29 Oct 2008 05:03 pm
Front Hub & Wheel bearing JoeHundredAire Wheels, Tires, Suspension 2 15 Jun 2008 11:25 am
front wheel bearing debspt Tech & Performance Forum 1 01 Oct 2006 11:42 am
