Grinding noise
Old 22 Jul 2012, 02:51 pm
Default Grinding noise
I have an '03 limited and there is a grinding noise that sounds like a brake rubbing,all the time. I've had a couple of mechanic's look at the pads and rotors and they are fine. We thought it was the tires rubbing on the shock housing,but I bought 2 tires for the front,and it still makes the noise.It sounds like it is doing it in time to the tires rolling. I would appreciate a diagnosis ,cause Nobody has a clue. By the way,don't bother telling me to go to a dealer,cuz I don't have the money!also by the way,it doesn't afect the drivability any.
Old 22 Jul 2012, 03:20 pm
Ray_Dockrey's Avatar
Default Re: Grinding noise
Sounds like you may have a bad wheel bearing. I found this thread that might help.
How to tell which front wheel bearing is bad?
AC Fan grinding noise shonenknife Tech & Performance Forum 6 27 Jun 2013 05:59 pm
Grinding noise while slowing down, whirring noise while speeding up thedarkcanuck Tech & Performance Forum 5 27 Nov 2011 10:15 am
Grinding noise. PtOnAir Tech & Performance Forum 6 10 Jan 2011 09:40 am
Another Grinding Noise... bjagd02 Wheels, Tires, Suspension 3 01 Nov 2010 09:01 am
Grinding noise SmittysGold Tech & Performance Forum 21 20 Oct 2008 07:25 am
