quick tie rod question.
Old 24 Jul 2012, 10:00 am
Default quick tie rod question.
I just bought a 2001 PT Cruiser from used car dealer. It was actually one of the salesman's take home car and maintained by the lot's mechanic. It runs fine. Just to be sure that everything was OK I also took it to my local pep boys and had them inspect it. They said that the motor mount and one of the outer tie rods need to be replaced, but it was more of a safety inspection issue. The inspection isn't due for 5 months and I'm not experiencing any steering or alignment problems whatsoever. How do I know if these repairs need immediate attention?
Old 24 Jul 2012, 10:29 am
UptownSport's Avatar
Default Re: quick tie rod question.
Look at both items.
Engine torque arm is very unlikely to cause a safety issue.
See posts on 3M windshield Urethane
Take out jack and lift corner they say is bad. Wiggle tire and see if it's loose.
Tie rods can and do fall off- a little play isn't immediate issue, but it doesn't get smaller ...
Old 24 Jul 2012, 02:41 pm
rcktpwrd's Avatar
both of those things aren't too bad to change yourself if you have any mechanical ability...
Joel
www.rcktpwrd.com
Old 24 Jul 2012, 05:09 pm
I live in the city and don't have a garage or driveway. Performing the repairs myself is basically a no go. My question is since the car currently drives fine, can wait a couple months on these repairs? And...how could tell if it would become a safety issue?
Old 25 Jul 2012, 03:32 pm
rcktpwrd's Avatar
I would say you have some time before you have to replace the parts. But I would get it fixed as soon as you are able to. With one tie rod being bad there is a very good chance that the other side is not so great too. I would have them all replaced at the same time. The longer you let it go the more uneven the tire wear will be as the 'loose' tie rod isn't keeping the alignment 100% correct all the time.
Joel
www.rcktpwrd.com
quick question superjew78 Wheels, Tires, Suspension 15 01 Apr 2012 06:50 pm
Quick Question Busa_Powered General PT Cruiser Discussions 3 10 Oct 2011 11:31 am
Quick S1 question. Morkeste Stage Turbo Kits 26 23 Jul 2011 02:03 pm
A quick question TheDarkAvengerX General PT Cruiser Discussions 9 10 Jul 2011 07:28 pm
quick question? LNBNDN General PT Cruiser Discussions 1 29 Dec 2010 11:24 am
