Rr Wheel play!!
Old 04 Aug 2012, 01:53 pm
Default Rr Wheel play!!
When I jack my pt up from the rear axle I can hold the right wheel at 12 and 6. I can move the wheel. Any one help me out?
Old 04 Aug 2012, 02:09 pm
Default Re: Rr Wheel play!!
Might be a bad rear wheel bearing but it's not an easy job.
This is from eHOW:
The rear wheel bearings are permanently sealed units within the hub and not serviceable on a PT Cruiser. A failure of the hub bearing requires replacement. The hub, however, requires several special tools and a heavy-duty press to remove the pressed in hub bearing. These tools are not normally found except in machine shops or service facilities. Removing the hub and sending it out to a facility that has these tools is the easiest and cheapest way to perform this job.
After posting that, what I see on the Internet are plenty of rear wheel bearing and hubs together and not too expensive so replacing the whole unit isn't such a big deal.
http://www.1aauto.com/1A/wheel-beari...sler/PTCruiser
Play in Steering Wheel Vjklander Tech & Performance Forum 4 21 Oct 2010 02:28 pm
Hub play... garner49 General PT Cruiser Discussions 2 16 Jun 2010 03:01 pm
help turbo play????? banlenterprises General Turbo Discussions 3 12 Sep 2008 01:22 pm
