Tire issue Pic Test
Like Tree2Likes
Old 21 Aug 2012, 12:35 pm
Default Tire issue Pic Test
I'll try here because it didn't seem to work in the tires/wheels section. Said it had to wait for approval... Just a little issue I'm having with my alignment I guess...
Old 21 Aug 2012, 01:56 pm
Default Re: Tire issue Pic Test
I didn't see it in any other section but I approved it here. Because of the SPAM here on the forum, you can't post more than one photo at a time when you a new member with just a few posts.
I'm gonna have to say something here. I don't think a bad alignment will do that to a tire. I may be wrong. I think you have had something go wrong with the tire itself, maybe the inside belt has slipped or moved or something like that.
Old 21 Aug 2012, 02:05 pm
cruserdad1976's Avatar
ok so what exactally are we looking at here???
Old 21 Aug 2012, 02:10 pm
UptownSport's Avatar
3d tire pic has tread separation.
I'd get a tape measure, an assistant and measure from known circumferential line (you can use tire crayon and a scribe, jack up tire and spin a line) and check alignment
I'd guess they are low quality tires; cheap tires, or should I say tires made expediently, have poor/short face belting.
OurPTGT likes this.
Old 21 Aug 2012, 02:15 pm
I've moved this thread to the correct section.
Old 21 Aug 2012, 04:47 pm
what date were they made? there should be stamp on the inside sidewall. something like 1612. 16th week of 2012, iirc
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 21 Aug 2012, 04:48 pm
your numbers will be different
Old 21 Aug 2012, 06:15 pm
I agree with CREWZIN not all this is alignment issues. Sticking caliper can cause enough heat to do this!
Old 21 Aug 2012, 07:09 pm
Also improper inflation can add to it...
Busted_PT likes this.
Old 21 Aug 2012, 07:23 pm
From the look of the outer edges that probably is a contributing factor!
Need Tire Help bryan888 Wheels, Tires, Suspension 7 09 Mar 2009 03:06 am
tire fit...once more lol superpug666 Wheels, Tires, Suspension 0 07 Nov 2008 01:40 pm
This is just a test.. repeat a test.... digitalpinscruiser Testing 2 12 Jun 2008 10:29 am
A little tire help PTGT Redman Wheels, Tires, Suspension 11 19 Feb 2004 01:41 pm
looking for one 17 " rim and tire bobs turbo pt Classifieds: Want To Buy 4 15 Mar 2003 11:27 pm
