subaru wheel swap?
Old 22 Aug 2012, 10:40 pm
Default subaru wheel swap?
I saw these online and I like the looks of them, and the price is good. I have a 2005 limited and for some reason they came with 15's instead of the 16's that I understand should have come with them. Everything in this description looks like a match but the offset is my worry. I have seen subaru's with pt cruiser 16's on them so I am thinking it would work. Can anyone confirm that the offset would be fine?
Subaru Impreza WRX
Offset: +53
Bolt pattern: 5x100
Wheel Weight: 16.5 lbs
OEM-equipped tire size: 205/55R16
Thank you,
-Norby
Old 23 Aug 2012, 12:30 am
2step's Avatar
Default Re: subaru wheel swap?
That +offset is way big. I wonder if it's a misprint and it should be 43 instead of 53. Contact the seller for a double check. At +53 it may be too close to the strut.
Old 23 Aug 2012, 03:34 am
808's Avatar
808 808 is offline
I remember the OEM offsets were pretty high. I think +53 may be right.
Hub-centric spacers my friend.
Old 23 Aug 2012, 08:19 am
Its the hub size that you have to worry about. I think it is smaller than the pt. Would have to be machined out a little. Goggle it to be sure.
Old 23 Aug 2012, 09:23 am
Ray_Dockrey's Avatar
The hub size is smaller. I had done some research on this swap before and the Subaru wheel has just a slightly smaller hub then the PT does. The PT is 57.1 and the Subaru is 56.1.
2step's Avatar
Maybe but it certainly needs to be checked out. I tried to search some info. The aftermarket tires that Tire Rack sells are +45 for 7 1/2" wide and +48 for 8" wide. The wheels the OP is considering are only 6 1/2" with 205mm tires so that could keep him out of trouble. Buttttt...... I've never run across ANY wheels with a +53 offset before, especially a 6 1/2". That's why I question if it's a misprint.
Old 23 Aug 2012, 09:37 am
Thank you all very much! I will check with the seller first, but it sounds like it wouldn't be such a great idea anyways.
-Norby
Old 23 Aug 2012, 09:59 am
I believe you to be right on the misprint. Know someone with pt wheels on an outback and they fit normal. Looks as if factory.
Old 23 Aug 2012, 10:17 am
According to this the wheel offset is indeed +53.
Master thread of OEM Subaru Wheel Specs - NASIOC
Cruiser / Neon wheel swap ? ? ? eddielives Wheels, Tires, Suspension 2 05 Jun 2012 07:31 pm
Swap Steering Wheel jessidusen Interior Accessories Forum 0 22 Jul 2007 12:07 am
Subaru WRX STi TripleJackInGA General Turbo Discussions 53 18 Sep 2003 12:46 pm
Blown away> subaru turbomangt General Turbo Discussions 15 23 May 2003 12:58 pm
