Alignment specs? '07 Limited.
Old 25 Aug 2012, 01:20 am
Question Alignment specs? '07 Limited.
Did a quick Google and didn't come up with anything.
Does anyone have the alignment specs for a 2007 PT Limited that they could post here?
Thanks!
Old 25 Aug 2012, 01:32 am
Default Re: Alignment specs? '07 Limited.
Never mind... As soon as I posted my question, I found a site with the relevant answer!
2007 WHEEL ALIGNMENT SPECIFICATIONS
Code:
        Caster (Range)   Camber (Range)  Toe-in
Front   +2.45 (+1.00)    +0.00 (+0.40)   0.00" to 0.40"
Rear                     +0.20 (+0.40)   0.00" to 0.40"
Old 25 Aug 2012, 10:12 am
I recommend to make sure you check or have checked for any worn suspension parts.
Tags
alignment
Torque Specs UZ4PLAY Tech & Performance Forum 15 02 Aug 2012 12:30 pm
Wheel Alignment Specs UnionJak Wheels, Tires, Suspension 0 16 Oct 2010 01:24 pm
torque specs? youngcruiser Tech & Performance Forum 8 21 Mar 2006 03:49 pm
Torque Specs irelandmoss Tech & Performance Forum 2 18 Jan 2006 09:07 am
Any know the specs on the following? crazie.eddie Tech & Performance Forum 2 17 Sep 2004 05:50 pm
