75k suspension maint.
Like Tree5Likes
  • 1 Post By rcktpwrd
  • 2 Post By 808
  • 2 Post By rcktpwrd
Old 30 Aug 2012, 05:14 pm
Default 75k suspension maint.
got a 02 that needs control arm bushings, but I want to work on the suspension once until 150k, and not every year. I've been reading in here and end up more confused. I don't want anything fancy, but I do want the 'best'.
I was thinking of ordering the set of bushings for everything since I have a good shop to press them out & in. I'm a little lost on what shocks/struts, new springs or not, and if moog ball joints are any good.
basically I want to put together a list for it all and put my pt on blocks once.
I have a diy mopar family, but my vocab is more electronic, so I need help with the planning stage. any help?
Old 30 Aug 2012, 05:51 pm
rcktpwrd's Avatar
Default Re: 75k suspension maint.
Moog for the ball joints and tie rods. I like the Energy Suspension poly bushings in black, you can get a complete kit for the PT. Probably get 100k plus out of that stuff... No need to replace springs unless you are looking to go lower. Any name brand shock/strut should be similar to stock...
XtrmDC2 likes this.
Joel
www.rcktpwrd.com
Old 30 Aug 2012, 06:09 pm
808's Avatar
808 808 is offline
For shocks and struts, KYB and Monroe seem to be fine replacements for stock. Tokico Blues are best used when lowering.
rcktpwrd and XtrmDC2 like this.
Old 30 Aug 2012, 06:27 pm
Note the poly bushings can squeak. They take a special lube for that.
Old 30 Aug 2012, 06:58 pm
rcktpwrd's Avatar
That is why I like the ES black bushings, most of them are graphite impregnated to help keep them from squeaking. Also you need to use plenty of the lube.
Joel
www.rcktpwrd.com
Old 30 Aug 2012, 07:10 pm
chigger_ns's Avatar
Did the ES black bushings, Love them, trust them, Good quality and no squeaky Squeaky!!!!
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 31 Aug 2012, 12:40 pm
rcktpwrd's Avatar
Cool Re: 75k suspension maint.
These guys usually have the best prices for ES stuff, I have purchased a bunch of stuff from them.
Energy Suspension 5.18108 HyperFlex Master Kit Chrysler PT Cruiser
shaggylive and XtrmDC2 like this.
Joel
www.rcktpwrd.com
Old 31 Aug 2012, 06:25 pm
Thanks Guys! just the info I was looking for. I guess the only remaining question would be about the bellcrank or whatever it's called. sounds like I'm better off replacing the whole part. I haven't noticed any clunking but it does wiggle pretty good by hand.
Old 31 Aug 2012, 06:54 pm
also should I find the bearings are worn, any hubs better than another one?
Old 31 Aug 2012, 07:07 pm
rcktpwrd's Avatar
Post Re: 75k suspension maint.
The Watts linkage and bell crank weren't making any noise in mine either but I did replace them and it tighten up the rear quite a bit. I also installed ES poly bushings in the linkage.
Rockauto.com probably has the best prices on those parts.
Bell crank part #905201
upper link #MS25133
lower link #MS25132
check the sticky at the top of this forum section...
Joel
www.rcktpwrd.com
Looking for suspension... HeavyMetalFL Wheels, Tires, Suspension 14 17 Jan 2011 03:48 pm
Suspension Duster Wheels, Tires, Suspension 3 03 May 2009 02:52 pm
Routine maint to improve performance Cajunsim Tech & Performance Forum 7 12 Mar 2009 02:29 pm
KW suspension lip Turbo Wheels/Suspension/Handling 19 24 Nov 2003 06:37 pm
Air suspension Ed Lim Wheels, Tires, Suspension 1 10 Sep 2003 05:13 pm
