Need tad bit of .....info :D
Old 02 Sep 2012, 10:39 am
Default Need tad bit of .....info :D
So yesterday i finally replaced my stupid wattslink :-) Took 2 hours and a LOT of picklefork usage to remove the boots. But i got it done.
Tomorrow is rear struts, and front monroe quick struts :-D YAY.
I have all the shocks/struts, i've got my spring compressors!
What i dont have is the correct 1/2 inch deep socket to remove the bolts!
My question to you all is..
What size are the rear strut bolts? I would hate to get the springs compressed and off the rear, just to have to put them back into go buy a socket that i dont have :-D
Any help would be awesome!
Old 02 Sep 2012, 11:54 am
Default Re: Need tad bit of .....info :D
The rear is composed of SHOCKS and separate springs. The springs don't have to be compressed or even touched. There's just a matter of some upper and lower bolts on the shock. Comes off and goes back on pretty easy. Any decent socket set will have the correct sizes. Best to have a set of sockets and wrenches. Sockets for the bolt on one end, wrench to hold the nut on the other end.
Old 02 Sep 2012, 01:04 pm
this i know. i just confused the word haha. what i need is to know what bolt head size the bolts that mount the shock are. I only have 1-2 1/2 inch sockets for my cheater bar. Thus i need to see if i have the correct socket, or if i need to pick up another :-)
Old 02 Sep 2012, 01:56 pm
If i remember right, the bolts are in the 17 - 18 - 19 mm range.
Old 02 Sep 2012, 04:16 pm
Just finished. Top bolt is a 15mm. Bottom is an 18mm :-)
Found an easy way to do it without spring compressors too! just need a small crank jack to support the rear axle , keeps the spring from moving :-) woot
SOME INFO PLEASE..... popkop Tech & Performance Forum 13 28 Sep 2011 03:51 pm
Need info cyann69 Exterior Accessories Forum 1 17 Aug 2011 01:43 pm
Anyone have info on this car? V8 RWD PT cleverklutz General PT Cruiser Discussions 22 06 Aug 2009 01:19 pm
a little bit of info for you 4SPEED Tech & Performance Forum 1 30 Jul 2008 08:35 pm
a little info please OurPTGT General Turbo Discussions 11 20 Oct 2003 07:16 pm
