Need help with new wheels.
Old 02 Sep 2012, 01:34 pm
Default Need help with new wheels.
Hi !
I bought new set of wheels.
It`s 18x7.5 offset is 48.
Will it fit to the front with 10mm spacers !? Without spacers they don`t fit
And what tire size should i get ?!
My PT is -35mm koni sport kit.
Old 02 Sep 2012, 02:11 pm
Default Re: Need help with new wheels.
It depends on the offset.
I have the same rim size, not sure about the offset, as u and I run
235 40's with no issues
Old 02 Sep 2012, 02:38 pm
2step's Avatar
Originally Posted by Multyashka View Post
Hi !
So you are saying the wheel spokes are hitting the calipers even before you mount tires? How thick of a spacer depends on how much overlap there is.
Old 03 Sep 2012, 02:48 am
Nope. Wheel spokes are`n hitting thw calipers at all.
The distance between the wheel and strut about 10mm =(
Old 03 Sep 2012, 03:43 am
808's Avatar
808 808 is offline
The offset is pretty high. A set of 10mm hubcentric spacers "should" do it. But what exactly is preventing it from being mounted?? Can you post pics please so we may diagnose the problem?
Old 03 Sep 2012, 09:46 am
2step's Avatar
Here's a comparison between a stock 205/50-17 and a 225/40-18 tire. Note that they are identical in every dimention but the sidewall. (And of course, a little more width.) This tire should just barely clear or need maybe a 3mm spacer at the most.
Specification-Sidewall-Radius-Diameter-Circumference-Revs/Mile-Difference
205/50-17.....4.0in.....12.5in.....25.1in...... 78.8in........ 804....... 0.0%
225/40-18.....3.5in.....12.5in.....25.1in...... 78.8in........ 804....... 0.1%
Old 03 Sep 2012, 01:27 pm
R18 7.5 width
R17 OEM Chrysler(painted in black) 215/45
Old 03 Sep 2012, 03:02 pm
808's Avatar
808 808 is offline
Thanks for the pics.
So it's not hitting the calipers nor touching the struts, and you said it's still not bolting on? How about the center bore? That's all I can think of at the moment. The PT's center bore is 57.1
Old 04 Sep 2012, 03:18 am
With the tires on and on the moving I think it will be hitting the strut =((
Old 04 Sep 2012, 04:35 am
808's Avatar
808 808 is offline
What size tires are you using?
WTT '06 GT Wheels for earlier GT wheels CruzinGT Classifieds: Want To Buy 1 05 Jul 2011 10:44 am
Wheels david14617 General PT Cruiser Discussions 4 09 Dec 2010 04:36 pm
big wheels xupd26jor Wheels, Tires, Suspension 1 06 Sep 2009 03:42 am
What wheels will fit an 01 PT? Bearcamp Wheels, Tires, Suspension 6 21 Aug 2009 03:35 pm
20 or 22 wheels funkyfermin Turbo Wheels/Suspension/Handling 4 06 Mar 2006 01:22 am
