parking brake with rear discs
  • 1 Post By Badglas
Old 14 Sep 2012, 11:19 pm
Default parking brake with rear discs
Hey out there in PT land, Does any one know how the parking brake works on a Cruiser with rear discs? Mine makes a slight noise after releasing it in the A.M. but it soon goes away.(right side only) This started after a complete brake job at a local independant shop. If I never set it there is no noise. I have had spotty service at this place and am thinking of going elsewhere. Anyone else had this problem?
2003 black on black Limited. 5600 miles. Auto
Thanks
Old 14 Sep 2012, 11:20 pm
Default Re: parking brake with rear discs
Sorry that is 56000 mi.
Old 15 Sep 2012, 06:44 am
I believe most cars have a small drum brake set-up inside the rear hub of the rear brake rotor used for the parking brake as you see in the picture below.
Old 16 Sep 2012, 02:43 pm
Thanks for the info. Should all of that been replaced as part of a rear brake job? I wonder if that was done.
Old 16 Sep 2012, 03:13 pm
Badglas's Avatar
It is unusual to wear out the emergency brake shoes, so they are not typically replaced. They should have been inspected if the rear rotors were resurfaced or replaced. It sounds like one of the return springs for the E-brake shoes is weak and/or broken. It is possible that the spring broke due to the rotors being removed, if the rotors were forced off. Having to force them off is not unusual, but an even better reason to have checked the E-brake components.
Ron
Busted_PT likes this.
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Old 11 Nov 2012, 01:34 pm
One thing about those inner brake shoes on the emergency brake.
On our 01 we never ever used the emergency break ever, (its an Automatic)
This past summer we started getting a lot of noise from the back brakes.
I bought new rotors & pads and found out the shoes had basically rusted and delaminated.
Then it started breaking up in several big pieces. It sounded horrible when moving at lower speeds.
Even if they are not " Worn Out " they should be inspected and changed periodically.
Parking brake sticks betty2000 Tech & Performance Forum 3 24 May 2012 01:48 pm
parking brake stevas Tech & Performance Forum 1 04 Jan 2011 11:47 am
Brake Pads and Discs PTNoob01695 Wheels, Tires, Suspension 5 29 Aug 2009 06:30 pm
06 Touring parking brake discovering06 Tech & Performance Forum 2 07 Jun 2009 02:17 pm
Drum brake replacement Parking brake cable Dorkygrin General PT Cruiser Discussions 2 28 Mar 2009 07:53 pm
