Lower Control Arm Bushings Again
Like Tree2Likes
Old 24 Sep 2012, 09:58 pm
Talking Lower Control Arm Bushings Again
Well, my '06 PT needs lower control arm bushings again. Three years/36,000 miles on the first set. Now another three years and 30,000 miles more and the left one is bulging out with the right one not far behind. There must be a better way.
Old 24 Sep 2012, 10:38 pm
UptownSport's Avatar
Default Re: Lower Control Arm Bushings Again
You could do the prothane thine, they last longer, IDK if anyone makes spherical bearings- Don't thinks so- they're bigger round than Neon/SRT4
Old 25 Sep 2012, 03:45 am
WoW
i got 150k+ out of my OEM lca's and they did look to, to bad
Give the poly's a try this time
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 25 Sep 2012, 04:13 pm
rcktpwrd's Avatar
Better bushings are the answer. Poly from Prothane or Energy Suspension, not sure if the Moog ones are poly but I'm sure they are better then stock...
Joel
www.rcktpwrd.com
Old 25 Sep 2012, 05:01 pm
It is not the bushings themselves wearing prematurely but either the road conditions or another suspension part needing attention.
Changing to Polyurethane or any other bushing material type may increase your wear factor but not solve the problem why they are wearing so fast.
Old 25 Sep 2012, 05:05 pm
Originally Posted by NitroPT View Post
It is not the bushings themselves wearing prematurely but either the road conditions or another suspension part needing attention. Changing to Polyurethane or any other bushing material type may increase your wear factor but not the problem why they are wearing so fast.
Yep, what he said! Along those line it could be that your original arms are damaged?
Have the front end checked out and just replace your original A Arms if they don't find anything amiss, grab another set and rebuild them.
Old 25 Sep 2012, 05:06 pm
Talking Re: Lower Control Arm Bushings Again
My understanding is that the lower control arm bushings wear out prematurely as did those on the Neons because of the design. I think the number of posts on this and other forums will reinforce the fact that the bushing failure is a known issue, just like the cooling fan.
XtrmDC2 likes this.
Old 25 Sep 2012, 05:16 pm
I have Energy Suspension bushings on both of my PTs.
Mine has 30k miles with them and my wife's has about 70k miles with those bushings and they are still good.
How to rebuild control arms.
NitroPT likes this.
Old 25 Sep 2012, 05:29 pm
It was only a suggestion of thought to look into other reasons for a seemingly faster then usual bushing wear. WE have no way of knowing from your first post how you drive,what maintenance you have had done or the conditions of the environment you drive your PT. If this pre-mature bushing information found on forums was reality then many PT's would have been covered under the standard warranty package and TSB's been reported. This is not the case as a quick review of TSB's would reflect. As with many things posted on forums when a few have issues it soon becomes a forum "urban myth" that somehow generates into a "fact"?
Old 25 Sep 2012, 05:50 pm
Something many do not know but you can custom order bushings with a different Durometer rating. All the bushing offered from most suppliers are usually a #70-80 which is a general application. This is generally in between not as soft as OEM but not so hard that you would lose teeth.
If you run upgrade suspension parts going to higher durometer #'s is sometimes a bennifit.
problems with lower control arm bushings ValAir Turbo Wheels/Suspension/Handling 37 10 Aug 2015 06:59 am
lower control arm bushings mdskinner731 Tech & Performance Forum 5 25 Jun 2012 10:03 am
Help; Are these lower control arm bushings bad? Christopher561 Wheels, Tires, Suspension 9 18 Nov 2010 09:54 pm
Lower control Arm Bushings BOLT Madturtle Tech & Performance Forum 3 10 Jun 2009 02:00 pm
Lower Control Arm Bushings at 25K miles???? NewPTCruiserInPA Wheels, Tires, Suspension 23 30 Nov 2008 07:21 pm
