Installing my FK coilovers (lotta pics)
Like Tree12Likes
Old 25 Sep 2012, 12:00 pm
Teska's Avatar
Default Installing my FK coilovers (lotta pics)
On wednesday 15th of august I've mounted my coilover set. I'm going do do a bit of explanation here, accompanied by a decent amount of pics.
First I jacked-up the front of the car:
Then loosen these 3 nuts:
And these nuts too:
Take out the part and use the right tool for the job:
You got to use the topmount for the coilovers:
So you have to remove it:
I decided to take the bearing appart en re-lube it:
In terpentine:
The cleaned parts:
The grease:
And the bearing looks like new:
Mount it on the coilover:
EDIT: I 've made a mistake here by leaving the blue washer on it. The coilover made strange noises like the spring wound itself up and loosened again, but that was the washer putting tension to the wrong area. By disassambly the washer was completely broken to bits.
rcktpwrd likes this.
PT Cruiser 05 base 1,6 liter Electric blue.
Natural gas system build in.
Lowered with FK coilovers.
Installed Mopar sub !
Old 25 Sep 2012, 12:01 pm
Teska's Avatar
Default Re: Installing my FK coilovers (lotta pics)
Mounting the coilover doing the opposite handling:
I don 't have many pics of the rear because it was +30 celsius and I was getting tired.
To put in the adjuster piece, you 'll have to get this off:
The aluminium piece, in the center of the pic, goes on there:
Mount the piece back and put the spring in place:
Mounting the shortened shock absorber:
And get this result:
Before:
After:
Front:
Dropped from 66,2 cm (this was with 1" springs allready mounted)
To 62 cm:
Back:
Dropped from 70,7 cm on stock springs:
To 66,3 cm:
So fronts - 6,5 cm and back - 4,4 cm give 'n' take.
Old 25 Sep 2012, 12:03 pm
Teska's Avatar
I've created a new thread about this so people find it more easily if they want some guide.
Old 25 Sep 2012, 12:11 pm
looks good
nice job
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 25 Sep 2012, 12:21 pm
I see you have the rear adjustment on the top...Is the first time I ever see that ... Are you sure it doesn't go at the bottom, just like the DieselPunk did? IMO you installed them the wrong way
Old 25 Sep 2012, 12:31 pm
Teska's Avatar
Well, at first I was also sure that it had to go to the bottom cause, like I have it now, I can 't reach the adjuster with the wrenches.
But then I saw that:
1. The writing on the spring suggested the opposite.
2. The adjuster can only be fastened at the top, there is no possibility to fasten it to the bottom.
So I 'm 100% shure I did it right
Old 25 Sep 2012, 12:35 pm
So DieselPunk did it wrong
BUT, what do the instructions say ? and why it can't be adjusted at the bottom?
Old 25 Sep 2012, 02:08 pm
OK I see what the question is about the rear setup. That is very strange? It's kind of a shorter shock with a spring adjuster setup. Are all the rear coil over kits like that?
I understand how it works, just never seen that before. And thanks yet another great write up!
Old 25 Sep 2012, 02:19 pm
Teska's Avatar
I understand that dieselpunk had it done by a shop and I assume the people there thought it was too much work to take off the baseplates to bolt on the adjuster.
I don 't understand how in earth they fastened it, if it were possble I would 've done it that way. So I'm afraid they didn 't fasten it and it just sits there pressed down by the weight of the car. That way it comes loose when you drive fast over a slope...
And there were no instructions with the coilovers.
Old 25 Sep 2012, 02:38 pm
im just curious.. don't the shocks prevent that from happening?
is there free play in the springs when the suspension is fully extended?
i'm only asking because i don't know..
looking for coilovers Dimitry Classifieds: Want To Buy 3 06 Mar 2012 08:27 am
whole lotta shakin goin on drsnutz46 Wheels, Tires, Suspension 2 29 Aug 2011 10:07 am
FS KW Coilovers halfpastdead Classifieds: For Sale/Trade 1 22 Feb 2011 06:21 pm
RS coilovers jas333 Vendors & Buyers Forum 0 24 Oct 2009 06:38 am
coilovers gt_tuner Tech & Performance Forum 1 08 Mar 2004 01:33 am
