Painting lowered springs
Like Tree10Likes
Old 06 Nov 2012, 01:27 am
Teska's Avatar
Default Painting lowered springs
I 've got red lowered springs for my PT that I wish to install for the winter and to go to the tech inspection in februari. Lowered springs are not allowed unless you spend a lot of money to clear them first.
So painting them is much easier and cheaper in the long run.
DoeIs Hamerite do the job ? Or will it peel off ? What kind of company does the stripping and painting of springs ?
PT Cruiser 05 base 1,6 liter Electric blue.
Natural gas system build in.
Lowered with FK coilovers.
Installed Mopar sub !
Old 06 Nov 2012, 01:45 am
808's Avatar
808 808 is offline
Default Re: Painting lowered springs
I would look into powdercoating as the springs do flex causing chips that we can't eat.
Eibach's come powdercoated black.
Old 06 Nov 2012, 01:54 am
Us old time Hot Rodders painted our springs years before powder coating was popular. Painting will hold just as well as painting anything else on the vehicle. In fact Epoxy Paint is available in rattle can and is much harder and more durable then most normal application of powder coating. But it only comes in 3 colors, Black ,whit and satin Black.
Your springs would need to be sand blasted or chemically strip to be powder coated. But to use the Epoxy a light sanding is all that is needed. Even painting over powder coated surfaces.
VHT Epoxy All Weather Paint
Teska likes this.
Old 06 Nov 2012, 02:38 am
Teska's Avatar
Thanks Nitro, this is a big help. Just ordered two cans from a UK web-seller. Inexpensive too.
Old 06 Nov 2012, 02:43 am
Teska's Avatar
Eibach's will cost me $250 while the red springs are laying in my garage
Old 06 Nov 2012, 02:58 am
808's Avatar
808 808 is offline
Was just giving a reference as to which companies also powdercoat their springs. Another one is Candyman.
But anyways, listen to Nitro.
Old 06 Nov 2012, 12:36 pm
Teska's Avatar
All stock spring are powder coated, it 's only the cheap ones who are spray painted, which loosens after some years.
Old 06 Nov 2012, 06:27 pm
Why the heck can you not lower your own car?
Old 06 Nov 2012, 06:42 pm
I would think it would be a public safety issue? Look how many incorrectly lower their own vehicles in the US.
Besides as for laws or regulations governing the lowing of vehicle here in the US goes...
Its not surprising you would be almost in vehicle code violation here in CA, naturally subject to the officer discretion! Right CREWZIN!
V C Section 24008 Modification of Vehicles
24008. It is unlawful to operate any passenger vehicle, or commercial vehicle under 6,000 pounds, which has been modified from the original design so that any portion of the vehicle, other than the wheels, has less clearance from the surface of a level roadway than the clearance between the roadway and the lowermost portion of any rim of any wheel in contact with the roadway.
Texas
Requirements
Texas law requires headlights for all motor vehicles be between 24 and 54 inches off the ground, measured from the center of the light, or lamp. This law applies to all vehicles, including passenger vehicles, motorcycles and mopeds.
Warning
Vehicles must have headlights that meet the state's height requirements in order to pass a Texas vehicle inspection. Headlights that are not the legal height will result in the vehicle failing inspection until the problem is corrected.
Now if I do the math with the Super Slammers that puts you below the required minimum in your state...
Old 06 Nov 2012, 06:47 pm
There are a lot of rules in the uk. This is one more reason that we need to eliminate any leaders that want to make us more like our European cousins. The people are great there government rules not so much.
LOWERED SPRINGS AND LIFT?? Wolfman Wheels, Tires, Suspension 2 29 May 2011 04:47 pm
LOWERED or NOT Wolfman Wheels, Tires, Suspension 9 14 Apr 2011 11:08 am
lowered 2 in souptownyamaha Wheels, Tires, Suspension 2 20 Jun 2004 11:25 am
Lowered bigdogdad Exterior Accessories Forum 23 23 May 2004 07:27 am
Lowered with PT-Tuning Springs GTSteve Turbo Wheels/Suspension/Handling 29 26 Oct 2003 10:36 pm
