control arm fun. WEE!
Like Tree3Likes
Old 21 Nov 2012, 09:28 am
Default control arm fun. WEE!
so yesterday i took on the job of rebuilding my front control arms with balljoints OURPTGT was nice enough to send me, and a prothane bushing kit i purchased. my mechanic friend said just to order new arms, then he ordered me new arms just in case. he said he could always return them.
i cut the big bushing apart and got it ready for the new one, then i pressed out the long bushing and the balljoint. well, long story short, the new ball joint fit way too loose in the control arm. it jiggled in the hole and wouldn't have been safe. maybe i messed it up with the press? IDK. HMPH. that turned out not to matter very much because the passenger side arm had to be torched off anyways. i'm glad he knew better and ordered the new arms. i broke one of the swaybar links. i had a bad drivers side tierod. i could pull it up and down appx 1/8".
now i have new arms, new front tires, a new tierod end, and new swaybar links. it's like a different car. all rattles and popping sounds are gone. it's great. i think the low speed clunk people hear is caused by worn sway bar links, not the bar bushings. i left those, and my clunk is gone.
Uptown: i saved the metal bushing insert you wanted me to measure ages ago. i can either measure it for you, or send it to you. let me know if you still need that
if anyone with a decent post count wants the prothane kit and balljoints to use, i'll send them to you for a case of beer(or free).
fyi, they have all the service records for this car, the front arms lasted 140k miles
here are three pictures of my misery for you all to enjoy:
Old 21 Nov 2012, 09:40 am
Default Re: control arm fun. WEE!
oh, also since i put the new tires in front..
he recommended i watch this michelin safety video, showing why shops are required to install the new tires in the rear.
a funny thing i noticed is where the car spins out at 1:17, he steered into the slide and purposely made it spin out.
Old 21 Nov 2012, 09:43 am
i cut the big bushing apart and got it ready for the new one, then i pressed out the long bushing and the balljoint. well, long story short, the new ball joint fit way too loose in the control arm. it juggled in the hole and wouldn't have been safe. maybe i messed it up with the press? IDK. HMPH. that turned out not to matter very much because the passenger side arm had to be torched off anyways. i'm glad he knew better and ordered the new arms. i broke one of the swaybar links. i had a bad drivers side tierod. i could pull it up and down appx 1/8".
I be insterested in these.
Old 21 Nov 2012, 09:58 am
PM me your address, i'll send them out (:
Old 21 Nov 2012, 03:56 pm
UptownSport's Avatar
Why did they cut the arm?
The vertical bolt seize to the steel bushing??
Thanks! Just the measurements would be great!!!!
Michelin is absolutely right; rear loses traction rear en swigs around an car is out of control- Front car continues straight until traction regained
Old 21 Nov 2012, 04:27 pm
we cut the arm with the torch and cut the rubber off with an airsaw in order to heat the metal sleeve the bolt passes through. it was a PITA but it worked great to get the stubborn bolt out. the arm was last replaced in 2006 at 104k miles. i'm at 248.5k miles now
i'll PM you measurements as soon as i get a chance to sit down and do it properly.
Old 29 Nov 2012, 04:00 pm
[QUOTE=rob342;456814]so yesterday i took on the job of rebuilding my front control arms with balljoints OURPTGT was nice enough to send me, and a prothane bushing kit i purchased. my mechanic friend said just to order new arms, then he ordered me new arms just in case. he said he could always return them.
Thanks for the gift they arrived today. Now that's Street Cheese! Rob you also get the strongest packaging award. I thought I was in after I cut the fiberglass tape but no the two sided industrial strength tape still had a firm grip on my treasure. As you see in the picture I finally got at them. Thank's again for the free stuff. will use these on the dream when I restore it.
rob342 likes this.
Old 30 Nov 2012, 12:33 pm
Sorry those ball joints didn't work out for you
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 21 Nov 2015, 08:54 am
yeah? YOU SHOULD SEE HOW I SHIP HEADS!!! i even had lag bolts through a couple head bolt holes holding them to the bottom.
Old 21 Nov 2015, 12:55 pm
I had the same experience with ball joints purchased from NAPA
and the bushings were already tearing after 3 months.
I thought about tac welding the ball joints in even thought they came with outside retaining circlips.
rob342 likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
control arm help cowboyinboxers Wheels, Tires, Suspension 3 03 Apr 2012 06:02 pm
control arm bolts Flowrider Wheels, Tires, Suspension 8 19 Mar 2012 09:56 pm
FS-Energy Susension urethane control arm kit and control arms nuptgt4me Classifieds: For Sale/Trade 0 18 Mar 2010 05:31 pm
control arms AlexJB Classifieds: For Sale/Trade 0 29 Aug 2008 01:01 pm
Out Of Control CHROMEDCRUISER General PT Cruiser Discussions 15 03 Mar 2005 05:05 pm
