Road Noise or something more?
Old 30 Nov 2012, 08:14 pm
Default Road Noise or something more?
Ok tomorrow i will be jacking up the '08 and checking the brakes and such on the front. I had thought that there was allot of noise coming from the right side, thought it might have been the worn tires so put new tires on the front but the "road noise" is still there. however there are time that the noise subsides, sometimes pressing the brakes silents the noise and sometimes it doesn't. I replaced the brakes and rotors several months ago before i did the tires, again thinking it was the tires. Anything else I need to check will having it jacked up? Thanks!!!
Spooky
2008 Touring Edition 26,000 Miles
R.I.P. Penny
2001 - Limited Edition - 234,067 + Miles
120,000 spark plugs Bosch Platinum 4
135,000 - Timing belt,
170,000 - Radiator
190,000 PCV and hose
200,000 Spark plugs Bosch Platinum IR Fusion
200,235 - Oil Sensor
Old 30 Nov 2012, 08:22 pm
Default Re: Road Noise or something more?
Sounds like you may need wheel bearings.
Old 01 Dec 2012, 12:37 pm
Yeah i was afraid you were gonna say that!!!!! i had a feeling it was. just called and they want over $300.00 to replace the hub and bearing, now looking on ebay, i found this.
Dorman 930 300 Front Wheel Bearing Hub Assy | eBay
that is pretty much all i need correct?
Spooky
R.I.P. Penny
170,000 - Radiator
Old 01 Dec 2012, 03:15 pm
compdr59's Avatar
Should be under $200 installed. Call someone else. The hub is probably good.
Original Owner 135k
Old 01 Dec 2012, 04:49 pm
Ya,the wheel hub is good. You need the bearing, witch is not included in that add. Although the wording is a bit confusing. That price is really high. Check around. They all go in the same way. Nothing out of the ordinary on the pt.
First Road PT Road Trip PappyRoot General PT Cruiser Discussions 2 30 Mar 2012 09:00 pm
My Car Makes Hissing noise when driving.. no noise from reverse or netural kasasoze Turbo Performance 3 04 Dec 2011 09:07 pm
Road noise / exhaust noise in the car. jackatg450 Tech & Performance Forum 3 21 Jul 2004 10:55 pm
Reducing road noise? Ctown General PT Cruiser Discussions 16 06 Jun 2004 02:04 am
Road Noise Ron Perkins Tech & Performance Forum 10 22 Feb 2002 06:49 pm
