Has anyone lowered the rear with lowering springs?
Old 09 Dec 2012, 12:00 am
needmoretoys's Avatar
Default Has anyone lowered the rear with lowering springs?
Is there anyway to lower the rear end besides using springs and bags. I was thinking of maybe raising shock mounts. Maybe change the hight of the rear spindels. I think I might get a rear I-beam at the junk yard and see what can be done. Guess it might be time to buy a welder.
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 09 Dec 2012, 12:40 am
Default Re: Has anyone lowered the rear with lowering springs?
Can the lower spring perch be moved down or the uppers be moved up?
Lenny
Old 09 Dec 2012, 06:07 am
Teska's Avatar
You can NOT lower the car WITHOUT shorter springs unless you cut your stock springs which is stronly advised against. And peronally I don't understand what the hussle is, there are springs on Ebay for less than $100...
PT Cruiser 05 base 1,6 liter Electric blue.
Natural gas system build in.
Lowered with FK coilovers.
Installed Mopar sub !
Old 09 Dec 2012, 10:59 am
2step's Avatar
The rear is super easy to change springs and lower the back if you have a floor jack and jack stands. In some cases it's possible to do it in a few minutes without removing the wheels or diconnecting the shocks. Worse case, if you have to remove the wheels and shocks, it becomes a half hour job. As far as I know, lowering springs are sold new in sets of 4 but many owners have purchased sets cheap enough and just not utilized the fronts at all.
A lot of owners feel that the rear sits a bit higher than the front. This is because the Cruisers are designed to carry a load in back once in a while so the rear starts out a little higher. Because lowering shortens the suspension travel, the bump stops should be cut down a couple inches. While you're changing the springs, just twist the stops out with your hand, chop off an inch or two and shove them back. It's a good idea to go with firmer than stock shocks to prevent bottoming out but you can wait on that to see if you really have to do that step later on.
Old 09 Dec 2012, 07:49 pm
You guys missed the point completely. If you were to somehow raise the rear spindles you would keep the factory ride but lose the factory ride hight. I have mine lowered about 3.5 inches now and I really don't like the way the spings fit in there. They are alot shorter then the stocks. I can jack up my car right now and pull them out without removing the shocks. What I'm thinking is to make a new mount on the Ibeam that would raise the spidle up maybe 3 or 4 inches. I haven't gotten to really look at it to see that it can be done or not.
Lenny
Old 09 Dec 2012, 08:30 pm
2step's Avatar
That's what happens when you title the thread "Has anyone lowered the rear with lowering springs?" like you did.
Very very few people have dropped 3 1/2" and want to go lower yet. Here's one of the few......
More Lows?
Old 09 Dec 2012, 08:59 pm
More Lows?
Damn how did I do that one. I meant to say without. Sorry about that. I'll see if I can change it.
I cant edit the title.
Lenny
Old 09 Dec 2012, 09:15 pm
Default Re: Has anyone lowered the rear without lowering springs?
Maybe Crewzin can edit the post to say without lowering springs.
Lenny
Old 10 Dec 2012, 12:12 am
I would not recommend doing this unless you are a suspension designer or have someone that does suspension design, fabrication of performance specialty components with experience in suspension designs.
The PT rear suspension consists of an axle with a watts link, spring,shocks and wheel hubs.
Those wheel hubs are attached to the axle with 4 harden fasteners and nuts. It would be very easy to fabricate a flat braced steel spacer/bracket that would relocate the hub upward. This would lower the PT's rear end without the need for special lower then stock springs. You would have to do careful measurements and adjust the bump stop for the shorter axle upward travel.
Old 10 Dec 2012, 12:52 am
Thats what I was questioning myself, would there be less wheel travel? The suspension would be in the factory possition only the wheels would be moved up., lowering the car. I just wasn't sure of what would happen.
Lenny
Just need rear lowering springs jwlast Tech & Performance Forum 3 05 Jun 2012 09:28 am
Rear Lowering Springs WHICH way is TOP rspiegel Wheels, Tires, Suspension 0 21 Nov 2009 06:18 pm
WTB: Rear Lowering Springs slayerdarkcross Classifieds: Want To Buy 0 28 May 2009 02:50 pm
wtb: rear lowering springs theone Classifieds: Want To Buy 1 18 Sep 2008 02:57 pm
Rear Lowering Springs Only hodgecr Wheels, Tires, Suspension 4 18 Jun 2007 11:54 am
