Odd Front end noise.
Old 10 Dec 2012, 12:05 pm
Default Odd Front end noise.
So earlier this year i started hearing a popping noise whenever i hit a bump coming from my front end on the passenger side on my 03 2.4 non turbo
When i had my annual inspection i failed due to a leaking strut, oddly enough on that side.
Well i replaced the suspension in in the front end. Sound was still there. So upon further inspection haha i realized i had somehow sheared off one of my swaybar links. whole lower bolt head was gone and the swaybar was just hanging. So i replaced both links.....
Noise still remained.
Took it a whole step further and replaced both control arms with ones from autozone, ripped off the bushings and threw on some nice tough moog ones.
POPPING IS STILL THERE . Looked at my tie rods, no play in the wheels at all, axles are in great shape, boots are solid........
what in the heck is causing this annoying popping sound? it sounds like i have a broken strut, but my front suspension only has 45 miles on it. :/ and im stumped.
Old 10 Dec 2012, 03:49 pm
Default Re: Odd Front end noise.
Here's a few posts to go over....
noise from frontend
popping noise when turning
Popping sound while driving
Carolina PT Cruisers - Front End Popping Noise?
Popping noises in front end. Please help! - DoItYourself.com Community Forums
One Thing Leads To Another With A Popping Noise
Old 10 Dec 2012, 06:56 pm
Take a look at the sway bar mounting bushings. Been some reports of these causing a sound like that. Then there is the strut upper swivel bearing.
Old 12 Dec 2012, 03:30 pm
OOOO that could be it!. because as i said ive changed everything else, but those two mounts for the swaybar itself near the middle have never been touched! ill check that out tomorrow, im gonna replace a wheel bearing on the drivers side that somehow got some grit in it and is grinding a bit . so thats the perfect time to look! thanks!
front end noise wcerqua General PT Cruiser Discussions 1 05 Jun 2012 08:23 pm
front end noise Luvour04ptgt Wheels, Tires, Suspension 2 29 Sep 2010 07:45 pm
Front End Noise Luvour04ptgt Turbo Wheels/Suspension/Handling 0 03 Sep 2010 10:31 pm
FRONT END NOISE??? help mjb457 Tech & Performance Forum 3 13 Mar 2010 12:41 pm
?? Noise From The Front :( hicomp Wheels, Tires, Suspension 7 17 Oct 2008 02:36 pm
