Front Wheel Bearings
Old 18 Dec 2012, 08:19 pm
Default Front Wheel Bearings
I just changed my right front wheel bearing. I was skeptical and nevous as I have heard these are a bitch without a press. Therfore I have a tip which may help some. I bought the bearing kit at Harbor freight for 99 bucks. After removing the knuckle I hammered out the hub with a 1 1/4 inch socket from the back. After that I cut a slot into the inner race still left on the hub, very carefully. Once you get a nice groove, whack it with a chisel and it comes off with your hand once it opens up. Using the correct spacers in the bearing kit I started hammering the outer race after I removed the shield, just to get it going. Grease the threaded rod that comes with the kit, and the washers that contact the nuts. This ended up being too slow so I hammered out the outer race too using the spacers and a socket to protect the spacers. Ok, cleanup the knuckle and hub with some fine emery cloth.
Freeze the new bearing in your freezer. I put mine in a couple days before I did the work. Heat up the knuckle to a couple hundred degrees. I used my gas grill as I am sure my wife would not have appreciated this in our cooking range. This is the tip. If the knuckle is hot enough the bearing drops right in! This is an old tip I used in motorcycle rebuilding with aluminum cases, but the same applies. I forgot to mention to freeze the hub while you are heating up the knuckle. I used the bearing kit to pull the hub into the bearing. The whole job took 1 1/2 hours.
Quick Q about front wheel bearings... thesameguy Tech & Performance Forum 6 12 Oct 2012 08:34 pm
Finally got my front wheel bearings replaced! sscanlan General PT Cruiser Discussions 0 14 Jan 2012 07:22 pm
SKF or Timken front wheel bearings? Samson Tech & Performance Forum 7 08 Jan 2012 04:29 pm
Best front hub/wheel bearings to buy? Samson Wheels, Tires, Suspension 9 13 Aug 2010 11:45 am
How many front wheel bearings? scrisp2 Wheels, Tires, Suspension 0 22 Mar 2010 11:24 am
