Rear Squeek/creak
Old 27 Dec 2012, 01:40 am
SabreGrub's Avatar
Unhappy Rear Squeek/creak
Hello, my 2002 pt limited is acting up.
The rear end squeeks really loud when going over speedbumps and entering or exiting driveways with any speed. I've thrown the car up on ramps and sprayed all the bushings i can see with silicone and the squeek remains, no difference in volume. Its not quiet, its like really loud in the cabin and sounds terrible. Kinda metal on metal spring noise. I know the previous owner was an idiot and had a knack for hitting speedbumps at great speed so do you think it could be struts?
I checked the bellcrank and its good. sway bar bushings (first suspect) seem ok.
Any help would be greatly appreciated
2002 Cruiser Limited 43000 miles. lowered 1.5" rear, weight reduction, magnaflow exhaust, aFE intake
Old 27 Dec 2012, 03:18 am
Default Re: Rear Squeek/creak
Rear strut mounts are shot, probably internally, Remove a strut and look inside the bushing, its probably worn straight through. Good news is rear strusts on a 02 are cheap as hell :-p
Even after i replaced mine i had as squeak, turned out that i hadnt tightened the mounting bolts enough which was allowing a bit of play on the bolt.
Old 27 Dec 2012, 10:01 am
Check the spare tire, too - if it's loose it can squeak.
Old 27 Dec 2012, 11:09 am
This time of year you may be getting a lot of salt in the air where you live in San Diego CA. I lived in Santa Cruz CA for 13 years and I need to always lube up the rubber right around and after winter. I used RED LINE grease that seems to work better then anything else with the exception of my Polyethylene lubricant.
Silicone spray is a very short term lubricant for this condition. My guess is when you applied it that you had peace and quiet for about two day and then the squeaks returned?
Old 27 Dec 2012, 07:33 pm
Redline is very good, if you cant find it go to your nearest tractor supply and get some J31 5thwheel grease :-D that stuff lasts YEARS :-D
Old 28 Dec 2012, 01:52 am
SabreGrub's Avatar
Actually, i lubed em up and took it out and exactly the same squeek occured. im leaning toward the struts and strut mounts.
Old 28 Dec 2012, 09:49 am
Shocks are on the rear strut assemblies are on the front, you mentioned the rear?
Old 29 Dec 2012, 12:31 am
SabreGrub's Avatar
Yes im referring to the shock absorbers, its a habit to call all four struts as most modern cars ditched the live rear axle.
Rattle/squeek in rear passenger area - help!! dolemite General PT Cruiser Discussions 6 21 Oct 2008 09:21 pm
Driver Side Rear rattle or squeek Imdaddog PT Cruiser Convertible Forum 1 28 Nov 2007 01:06 pm
Rattle/squeek in dashboard robinjoe General PT Cruiser Discussions 1 05 Apr 2007 10:24 am
Annoying squeek in dashboard robinjoe Interior Accessories Forum 3 30 Mar 2007 10:06 pm
No more squeek turbomangt General PT Cruiser Discussions 3 15 Dec 2003 09:20 pm
