Best way to check tie rods & struts
Old 04 Jan 2013, 10:28 am
falconut's Avatar
Default Best way to check tie rods & struts
You guys have been greast in answering all my previous questions. I've still got my 2007 NA Base model. It's got just over 85,000 miles now. I'm going to be doing my front brake pads again tomorrow, it's been about 40,000 miles since last time.
I figured that since I'll have the front tires off the ground, I might as well see if I can check the tie rods. I'm using a jack to raise it up, then placing a jack stand under the frame, this will raise just the one side front at a time. Not sure if you need both up to check them. Any explaination would be appreciated.
Also, what is the best way to check the condition of the front struts, visual or a physical method. Since I'll be under there, I should be able to get a good look.
Again thanks in advance.
Old 04 Jan 2013, 01:09 pm
Default Re: Best way to check tie rods & struts
best way to check the outer tie rod end is by grabbing it right by the knuckle and pulling up and down. my left tie rod would go up and down 1/8" when i tried this, so i replaced it.
Old 04 Jan 2013, 01:12 pm
To check these just walk up to the car, place both hands on the hood and bounce the car up and down, if it bounces more than once when you stop bouncing it, odds are the suspension is going bad.
Struts are easy to look at visually, check for leaking fluid, cracks, broken bits etc, if they look normal,they are normal , if they are pissing hydrolic fluid or are bent, cracked....they are junk :-)
Old 04 Jan 2013, 01:35 pm
falconut's Avatar
Thanks guys, I'll try these and see. Any other suggestions are definitely welcome.
Inner tie rods serviceable? calvin Wheels, Tires, Suspension 18 05 Jan 2013 08:49 am
tie rods Azt021 Wheels, Tires, Suspension 1 24 Oct 2012 09:29 pm
WTB: 2.4 PT N/A PISTONS/RODS JCD Classifieds: Want To Buy 0 30 May 2012 08:45 am
Suspect tie rods L2fish Wheels, Tires, Suspension 0 12 Jan 2012 05:31 am
Real Hot Rods turbomangt The Detail Shop 0 05 Apr 2005 10:54 pm
