15 " tire plus
Old 21 Jan 2013, 12:32 am
Default 15 " tire plus
hii, i have a 2005 base model with 195-65 -15. can i go to 205-65-15without rubbing anything? i don't care about the speedo but want to go higher. i tow the car behind a motorhome and the car bottoms out. thanks in advance, jim
Old 21 Jan 2013, 01:11 am
Cool Re: 15 " tire plus
You will be fine with a 205
Not sure if you will gain the height you will need though if you are bottoming out.
Maybe put the pt on a small trailer and pull it?
I dunno, good luck
Old 21 Jan 2013, 04:34 am
Teska's Avatar
Default Re: 15 " tire plus
I think some helper-springs could get rid of you problem. That way the suspension won 't get so low. But as Busa said, 205 is no problem, but you will only gain 12 mm overall which means only 6 mm higher than stock
Maybe your struts are worn ?
PT Cruiser 05 base 1,6 liter Electric blue.
Natural gas system build in.
Lowered with FK coilovers.
Installed Mopar sub !
Old 15 Feb 2013, 04:43 pm
I run 205/60/15's with No Problem!
As the Guys above said, don't think it will help your bottoming out when towing it. Does it bottom out when you drive it? How do you tow it, on a wheel dolly up front and the rear bottoms out? Do you have it loaded with extra cargo/luggage like you would a trailer when you are towing it?
12 Regal Turbo
06 PT - Base with BLING! TRADED 5/27/13
01 PT LE - Kid's Car - TRADED 01/13
01 Beetle Sport - SilverSport - 150+ MPH
93 Del Sol - 32+ MPG
90 F150
73 Mach1
What tire pressure for 19"? trollware012 General PT Cruiser Discussions 4 30 Mar 2012 11:49 pm
'06 vert Turbo 18" wheel/tire ? CHOPS Wheels, Tires, Suspension 6 14 Dec 2011 08:09 pm
What is the Widest/Tallest tire on Stock 17" 03RedGTPT Wheels, Tires, Suspension 6 22 Aug 2009 03:26 pm
Tire size for staggered 20" Rear 18" Front ???? dpolley Wheels, Tires, Suspension 4 10 May 2009 09:54 pm
