unknown part in wheel well
Old 23 Jan 2013, 08:03 pm
Default unknown part in wheel well
So i decided to have some fun in my 2001 pt cruiser LE. I ended up in the ditch and some guy offered to pull me out. well he hooked up to a bar found in my wheel well (passenger side) that bolts on in 2 spots one to what looks like i think is my frame and on to the wall in the well. It ended up snapping in 2 and im looking to replace it but i have no clue what it is or what it does. I think it was connected at the bottom onto the same bolt that holds my sway bar in place. I know that its past the tie rod end toward the front. It only took one bolt (at the top) and one nut that was around the same bolt i think was holding my sway bar. It still handles mint and doesnt pull to one side or the other. Anyone have an idea of what the bar is called? I know that when i cut my wheel to the right you can look in behind from the front and see where it was. any names for this part?
Old 23 Jan 2013, 08:07 pm
Default Re: unknown part in wheel well
Pencil Strut?
Old 23 Jan 2013, 08:11 pm
Its at an angle just like this line ---> /
Old 23 Jan 2013, 08:24 pm
Pencil Srtrut can be seen in this picture. It is to the left.
http://www.z4k.com/lca/lower_control_arm_004.jpg
Old 23 Jan 2013, 08:30 pm
I dont think so
Old 23 Jan 2013, 08:40 pm
go to this video and you'll see the part at 1:52 pause it
Old 24 Jan 2013, 03:54 am
UptownSport's Avatar
My man is correct, sir! Pencil strut.
(Unless we really have a knucklehead on tow truck and hooked to BRAKE HOSE )
Old 24 Jan 2013, 10:53 am
Would you happen to know a part number for the pencil strut? cant seem to find it anywheres. Is it a bad idea to still drive it? even though i have been
Old 24 Jan 2013, 10:56 am
Yep 100% without a doubt pencil strut.
I think its a dealer part, i cant find a replacement one ANYWHERE online, but it shouldnt be too expensive.
:-D
Old 24 Jan 2013, 11:19 am
Go to your local craigslist under auto parts. Type in PT Cruiser. Then look for a part out call them up show them the picture that sanatanadharma provided and you will get one.
Or call a local auto dismantler and do the same as ^^^^
Question apon part broken in wheel well ptcruisn Feedback and Support 1 24 Jan 2013 03:56 am
Unknown radiator leak drewt1047 Tech & Performance Forum 10 30 Jun 2012 10:32 pm
Coolant leak from unknown part mzlaalaa Tech & Performance Forum 9 26 Feb 2012 04:16 pm
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
