`01 swaybar to `05 Cruiser?
Old 26 Jan 2013, 04:50 am
Default `01 swaybar to `05 Cruiser?
I have an `01 Touring Edit, 2.4 non turbo. Picked up an `05 2.4 non turbo Touring Edit. Would it be an easy swap to remove the front swaybar from the `01 and install it in the `05 ? Thanks for any info.
Old 26 Jan 2013, 09:51 am
Teska's Avatar
Default Re: `01 swaybar to `05 Cruiser?
It are the same cars so it shouldn 't be too hard to do.
PT Cruiser 05 base 1,6 liter Electric blue.
Natural gas system build in.
Lowered with FK coilovers.
Installed Mopar sub !
Old 26 Jan 2013, 10:42 am
2step's Avatar
All the anti-sway bars from all Cruisers are interchangeable with any other Cruiser, stock or aftermarket.
Old 26 Jan 2013, 12:00 pm
What 2step said and
I believe they are all the same size as we!!? You might want to measure them before going to the trouble of dealing them?
Now if you meant to say your 01 has rear sway bar, the by all means get it pulled and installed on your 05!
Old 27 Jan 2013, 04:02 pm
You can, but why? They are the same.
Now the rear would make more sense, because the '01 has one and the '05 doesn't.
Old 27 Jan 2013, 05:27 pm
I brought the `05 home and it's sitting in the yard with 1 1/2 feet of snow covering it. I thought the `05 Touring did not have the FRONT swaybar. Too cold to check at the present time.
Old 27 Jan 2013, 05:43 pm
I would be surprised to learn that there was any model PT that did not come factory equipt with a front anti-roll bar? At close to 4000lbs and most on the front it is almost a given that PT's need the front anti-roll bar.
swaybar help please ZDaytona Wheels, Tires, Suspension 2 31 May 2012 07:35 pm
Swaybar link torque specs 06PT Tech & Performance Forum 2 25 Jan 2012 04:07 pm
24mm vs. 26mm Swaybar? thesameguy Tech & Performance Forum 4 22 Jul 2011 01:35 pm
Installed the rear swaybar over the weekend...wow! Cal Cruzer Turbo Wheels/Suspension/Handling 42 15 Aug 2005 04:26 pm
Rear Swaybar parts & mounting help please Cal Cruzer General Turbo Discussions 5 22 Jan 2004 05:24 pm
