Renewing some worn wheels
Like Tree33Likes
Old 15 Feb 2013, 12:24 pm
Teska's Avatar
Default Renewing some worn wheels
I 'm currently in the middle of renewing wheels that I bought looking like this:
One of the centercaps was missing so I send an E-mail to the HQ of Ronal in Switserland. After an hour I got an E-mail back asking me for my postal adress and a few days later this was in my mail:
For free ! Talking about service !
I took the wheels to my tyreshop and let them take off the Pirelli tyres. The Pirelli's are by the junk now.
First I used a cleaner that is supposted to degrease 100%, here you see three wheels cleaned with a Scotchpad and the degreaser:
The wheel with the yellow paint on it has little dents in it because it's been laid flat onto the spokes and then there 's been something put on top of them. Normaly I had to buy some aluminum paste to fill them, but that stuff is way too expensive for the amount I need. So as a work-around I used Hamerite paint to fill them. This is a thick paint which gets real hard.
Here's where I 'm going to start sanding. Every wheel has damage from scraping against boardwalks and I had to use sandpaper grid 80 to get the edge smooth again.
The edge and the deeper dents have been sanded with a sanding-machine, sometimes I 'll end up sanding the aluminum itself.
Here I 'm dry sanding the cleaned wheels with a Scotchpad, making the paint flat:
Two wheels ready to paint:
Even the inside has been sanded to the best of my abilities:
Here 's the third wheel ready for painting:
But the worst one is nearly not ready. After sanding the yellow paint, the dents were filled 40%, so that 's good. I decided to do it again with red Hamerite paint so I can easily see when I 'm sanding too deep next:
All I can do now is wait untill the paint dries.... see you tommorow for another episode of "Ludo's painting his wheels"
rcktpwrd likes this.
PT Cruiser 05 base 1,6 liter Electric blue.
Natural gas system build in.
Lowered with FK coilovers.
Installed Mopar sub !
Old 15 Feb 2013, 12:32 pm
mityqwik's Avatar
Thumbs up Re: Renewing some worn wheels
very good work,hope you will post a picture of the wheels when done and mounted on the cruiser
Teska likes this.
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 15 Feb 2013, 12:36 pm
Default Re: Renewing some worn wheels
Lots of work to get ready to paint. If you don't want to see any previous damages. Good job.
Teska likes this.
Old 15 Feb 2013, 07:09 pm
Teska's Avatar
I haven 't shown the backside of the wheels... not repairable
Old 15 Feb 2013, 07:27 pm
You mean there toast?
Old 16 Feb 2013, 06:10 am
Teska's Avatar
On two wheels the girl driving the car, that had these one it, achieved hitting a lot of objects with the inside of the wheels. Luckily for me the wheel has sort of an extra rimm on the inside and I used a grinder (I think it's called so) to grind the bended parts away where they were in the way.
Is this named a grinder ?
Old 16 Feb 2013, 01:22 pm
rcktpwrd's Avatar
Yup that is an angle grinder.
The wheels are looking good so far. My fingers hurt just looking at all that sanding lol
mityqwik and Teska like this.
Joel
www.rcktpwrd.com
Old 16 Feb 2013, 01:45 pm
Teska's Avatar
Well since I'm home recovering from my dislockated thumb, I 've got the time. And I 'm trying to do a decent job on the sanding cause it would be a pitty if I discover, while spray-painting, that I didn't sand enough.
I want a pro-result for a DIY job
Old 16 Feb 2013, 02:04 pm
ROCKETMAN8060's Avatar
Is looking great. Love the wheels!
Teska likes this.
ROCKETMAN8060
Old 20 Feb 2013, 05:00 am
Teska's Avatar
Okay, yesterday I've been at it again !
Here 's the backside of one wheel, just to show you the damage been done:
As you can see (and this in ONE wheel), I had to grind away excessive material. So balancing the wheels will be some job
And here is the wheel with the red paint on it:
You can clearly see how the red paint had to fill in the dents where the yellow wasn't enough. Now the fourth wheel has been sanded and is ready to paint too.
Next up will be turning my garage into a spraybooth again.
worn bushings falente Wheels, Tires, Suspension 4 27 Nov 2011 09:24 am
Possible worn cv joint plus error code Laural Tech & Performance Forum 11 31 Jul 2011 01:26 pm
WTT '06 GT Wheels for earlier GT wheels CruzinGT Classifieds: Want To Buy 1 05 Jul 2011 10:44 am
Worn tie rod and bad tires- Anybody else? JCsGTPT Wheels, Tires, Suspension 2 17 Jul 2007 02:53 pm
2005 PT With a Worn Clutch PTDAN Tech & Performance Forum 17 26 Mar 2007 02:26 pm
