Suspension Advice
Old 23 Feb 2013, 02:03 am
Default Suspension Advice
I need to replace the rack and pinion and lower control arms on my 2004 with 110,000 miles.
What other parts should I replace while doing the job?
Thanks in advance.
Old 23 Feb 2013, 06:55 am
Default Re: Suspension Advice
Motor mounts might need looked at. Sure rack is bad?
Old 23 Feb 2013, 12:58 pm
Yes- i can see it leaking and the steering is noisy.
I already replaced the mounts.
Old 23 Feb 2013, 02:56 pm
My02RedRide's Avatar
Most likely will destroy the sway bar links trying to remove from control arms so I would replace those as well.
Old 02 Mar 2013, 06:29 pm
I got everything done. The PT is very quiet now. I appreciate your tips and advice.
Old 19 Mar 2013, 12:11 am
I replaced the brakes and rotors because I heard a squeaking sound and womp, womp, womp sound when braking. I didn't feel pulsating in the pedal but changed it all anyway.
I now hear a metallic sound coming from the passenger side wheel. The sound is loudest when I lean into a turn and in rhythm with the tire roll when going straight.
After replacing just about everything on the front end, I figured I was home free for a while. I replaced the wheel bearings 2 years ago.
Could it be the wheel bearing again? The wheel has no movement when trying to move it up and down or side to side.
PT Cruiser Base 111,000+
Old 19 Mar 2013, 01:46 am
UptownSport's Avatar
There's little shim thingys on the calipers or something-
They are different than a Neon so no experience-
Crewzin made a post so that's the only reason I know-
Old 19 Mar 2013, 01:52 am
Jack up the right front tire and turn it. It could be rust on the rotor from sitting, sticky caliper, etc.
front suspension noise - frustrated - need advice dadjmon Wheels, Tires, Suspension 8 20 Apr 2012 05:33 am
Front suspension advice classiccruiser Wheels, Tires, Suspension 12 31 May 2011 12:48 pm
Newbie Suspension Issue & Kit advice Sarasmiles Wheels, Tires, Suspension 12 27 Sep 2009 11:59 pm
Need advice for suspension change bluewasp Wheels, Tires, Suspension 12 27 Oct 2004 01:56 pm
Air suspension Ed Lim Wheels, Tires, Suspension 1 10 Sep 2003 05:13 pm
