215/55R17 Tires
Old 05 Mar 2013, 11:32 am
Default 215/55R17 Tires
New to group and dislike stock Low Profile RSA tires. I feel like I am riding on the rims. Has anyone been able to run 215/55R17 tires without rubbing the top inside corner of the front tires on the shock/strut spring plate? Have pothole damage to existing RSA's so I need to pick out new tires ASAP. Any help would be great. PS the PT is a GT convertible and not used in winter/snow.
Old 06 Mar 2013, 01:04 am
Chriscokid's Avatar
Default Re: 215/55R17 Tires
You'll see listed below, there's a number of old threads discussing tire sizes. My 05 gt has 205/50r17's which I like a lot. Keep in mind that the taller tires will lift the car higher which some people like, some don't .
Happy cruizin
[SIGPIC][/SIGPIC]2005 PT GT Vert
2004 Honda Aquatrax turbo Jetski
2006 Honda Aquatrax
1998 Dolphin 36' motor home
1949 Piper Clipper taildragger
Old 06 Mar 2013, 08:27 am
You ought to consider 16" - keeps speedometer the same and gives more rubber between road and rim.
Wheels and tires from TireRack - balanced, just bolt them on.
http://www.tirerack.com/images/wheel...e_f7_ci3_l.jpg
Got Michelin hydroedge tires, plus the wheels delivered to my door for $890 from TireRack last summer. I've paid more than that for tires alone!
YES, they will clear GT brakes - I have the same turbo front calipers on mine.
AND got a $70 rebate (limited time offer)
Old 06 Mar 2013, 10:47 am
2step's Avatar
No. I don't believe anyone has used a 215/55-17 tire. That size is 3/4" larger in radius which will definitely rub. It also has a 5% speedo error and probably same percentage of loss of pick up.
Old 07 Mar 2013, 12:40 am
Wink Re: 215/55R17 Tires
I use to always run 50 series with my Trans Am and Mustang 5.0.
I run 40 Zr's now and really didnt notice a difference with them, and this was before It was lowered a bit.
Sorry I am not much help but go with what your butt tells ya
Old 09 Mar 2013, 09:40 am
Thanks for your input. I decided on Continental Pure Contact, 215/50R17 tires on advice of Tire Rack. So much improvement over OEM RSA's. Went from driving a "Jeep" like vehicle to a smooth car. I hated to drive it on long trips as it bounced around the road on every groove or pot hole. I thought the PT had low torsional stability as it is a convertible. Bought the car as a year old dealer corporate car with less than 7k on it and thought the tires may have been the cause but suffered with them for another 13k miles. What a mistake that was as I liked everything but the handling/ride. Amazing what a tire change can do for a car's road stability.
The best tires Petey2506 Wheels, Tires, Suspension 12 27 Sep 2011 05:27 pm
Tires D_Mont Turbo Wheels/Suspension/Handling 1 09 May 2010 04:47 pm
New Tires, been running snow tires, bad me! DJmart Wheels, Tires, Suspension 9 13 May 2008 06:41 am
Name of these tires hankmaggard Wheels, Tires, Suspension 5 26 Feb 2008 12:42 pm
Tires CruzinAlong General PT Cruiser Discussions 8 23 Dec 2006 10:11 pm
